WD45
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: WD45
    Posted: 13 Feb 2022 at 4:51am
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 7:02am
I don't understand why you are waiting. That looks like a very well maintained tractor
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 7:20am
Couple things I spotted, Mower and both plows are missing important and harder to find parts. The tractor has mismatched rear tires. Headlights are missing and mounting is broken. The plus is the power steering and location is doable for hauling. I would contact Michael Crowe. He has some nice items for sale. He also loves to talk tractors. Just my thoughts.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 6:19pm
Les,
It has a few issues but has some good features like power steering, fairly complete, lots of toys to go with it.
If it runs really good, (fresh engine) it may be worth that. I would try to buy it for less, but that's just me. The implements may all need some work? The WD45 should pull three 14 inch bottoms in most soils.
Several things I see:
Not correct seat
Radiator may be from a WD, has the shutter hole. I don't think a 45 had that hole?
Rad shell has had the swoop cut for the 12 volt alt to be added
No Decals
Dents in grill shell and grill, and hood.
Right rear lower fender needs repair
foot step is bent in a couple places.
Starter rod handle bent way out of position.
As mentioned rears not matched. If that's important, that change can be $800.
Battery box side and top missing
Make sure std drawbar parts come with it.
Frame rails are rusty towards front. Maybe painted over other issues??
inside of front wheel not painted, again just a little shoddy workmanship on the paint.
All these items can be fixed, but for the price its not a great tractor. Maybe a good working tractor as it sets. Depends what you want or need??
Not trying to discourage you from getting it. Just some details.
I have brought home tractors in WAY worse shape than this 45. Most of them needed a lot more than I thought.
The power steering if good (he says it leaks) is worth $500 to $1000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 4:27pm
For various reasons I have decided to pass on this unit. Thanks for the opinions Smile
This page was generated in 0.031 seconds.
