Bought my first Allis Chalmers in a while.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Bought my first Allis Chalmers in a while.
    Posted: 12 Feb 2022 at 9:55pm
The guy called and said the backhoe is mine.
Tomorrow afternoon I’ll go put a battery and fresh gas in it and see if it will run?
Been sitting less than a year.
It will be nice if it will run and drive.
It’s way down in there with a couple sharp switch backs. Not super steep but tight quarters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 12:25am
good luck on your trip home...and if you find the front end is a little light, put sum dirt or gravel/rock in the front bucket, my backhoe was really light in the front, if it bounced you never knew where you'd be pointing when it came back down. sounds like a nice buy, we want pics!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 6:49am
Not sure if I’m gonna road it home?
It’s about 20 miles back roads to keep off main hiway and down a 6%
Grade on the hiway.
This route has about 8 miles of hiway but not main hiway and no trucks on this road. One back tire is suspect.?
I’m hoping to just drive it up off of the property to the county road. Then maybe down 5 miles of county road to the main hiway and haul it from there.
Hoping to pay my bosses son or someone to haul it from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 6:59am
What model??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 7:14am
What model??
I600 gasser been sitting about a year.
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 8:33am
Good luck Thad! Those Arkansas switchbacks aren’t to be messed with. Might want to toss in a clean pair of undershorts with the battery and gas!
Take some pics and no doubt here that you’ll get it running!
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 9:10am
Scott I’m gonna have Little Vernon drive it up out of there. I’ll have to drive the ole yeller Ford out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 9:23am
Hope you have an easier time than we did.. Boy bought a CASE 530 setting for 10 years.. He was going to "DRIVE" it out... I went and looked and told him he was dreaming..  Took the hoe off back in the woods... Jacked up the bucket and blocked the cylinders. Made a hitch to bolt to the bucket. Pumped up the tires... and pulled it a mile thru the woods, down the hill, around the bend, thru the ditch, to get to the gravel road where i parked the trailer............ Took an old FORD axle and mounted it to the hoe a month later. Boom was straight OUT. Made a hitch to bolt to the bucket and pulled it out like a trailer..
GOOD LUCK !!
Edited by steve(ill) - 13 Feb 2022 at 9:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 3:36pm
Worked on it a half a day and have it running and driving well.
One back tire is suspect or I’d drive it home. I can drive it to the main road no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 3:43pm
Clap   Clap
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 6:41pm
 Well,,,HOOORAY,,,three times,,,!!! I just knew you was gonna luck out on getting it running before the day is out,,,,
 3-4 cans of Walmart stop leak shoould do the trick on that ta'ar,,,,you don't want to leave it out afetr dark after you done got it running,,,,,,Clap
 'Course ,,you know we are wanting lots of pics,,,,,,Clap
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 7:59pm
GOOD LUCK !!
                  Then hooked it to Ford pickup and drug it home?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2022 at 7:56am
Joe I sent you a video of the initial start up.
You can hear it trying to hit on the 4 th cylinder.
After a couple minutes it cleared right up.
Ran amazingly well for sitting and not cleaning the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 6:23pm
Got the ole backhoe home safe and sound. She drove out under her own power.
Had to back out the first section to the first switch back and was able to drive the rest of the way.
I have a couple pics if somebody wants to post them.
I can’t from my iPhone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 6:48pm
  Hey Thad,,I just seen the video you sent and do believe you lucked out bIG TIME on that tractor,,,!!  No smoke out the exhaust,,,that right there is a Big Plus for sure!!ClapClapClap
Waiting on someone to post them pics for you,,,,,,you just as well take some more pics while you at it,,,,,Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 6:55pm
Thad, send me the pictures and I'll see what I can do. Congratulations on your purchase.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 7:12pm
Thank you Hubert.
I owe you my friend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 8:01pm
Here you go, Thad.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 8:19pm
Nice!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 8:43pm
Thank you Hubert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 5:08am
First order of business will be a tuneup kit next will be fluid change then throw away the plastic boat seats and wooden blocks under them.
The previous owner must of been a short heller.
Makes it very hard for my arthritic old self to get on and off.
Any suggestions for simple durable seats?
I have one extra WD type pan seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 6:22pm
That’s nice and certainly takes up all of that trailer! Don’t envy the switchback experience heading home!
D17 Series 1
Allis B- 1939
Allis B- 1945
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 6:32pm
That's the first A-C backhoe I've seen in a long time. Used one both digging and shutting graves, (human) at a cemetery I worked during the high school years. Most of their grounds equipment at the time was A-C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 7:20pm
seats ??? man you can't possibly be able to sit down with that golden horseshoe  stuck you know where !!!
That is a real nice  new toy !!!
Butt.....
I kind like the little crawler,looks like a fun toy as well....
Post Options Post Options   Thanks (1) Thanks(1)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 5:28am
Butt.....
Jay that crawler is the real Golden Horseshoe. My wife paid for it.
1937 m.
It’s actually in very good condition.
I intend to hear it run this spring.
This page was generated in 0.172 seconds.
