yellow forklift blues...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: yellow forklift blues...
    Posted: 09 Feb 2022 at 10:12am
sigh.. anyone know if it's possible to actually remove/replace the starter in an FPD50... with the Buda 4BD153 diesel engine in it ??
3 bolts hold it onto the bell housing (3rd bolt looks 'fun')
Starter gets lots of power, click, doesn't spin though.
Not batteries
Not 'stuck' (spun flywheel with prybar)
Not 'electrical' aka wiring
Also can I remove the 'starter starter' ? Box on top of the motor section.
I can remove the bolt connecting power to the 'strap' going to the motor,
'think' I can get the slotted screws holding the 'housing' to the starter mtg plate
also anyone have a real part number for one ??
All 'words of wisdom' appreciated..actually nice here +2,sunny which is good cause ,of course, it's outside, won't start and flat tire....I KNEW I should have left it in the 50* garage...sigh..
jay
Edited by jaybmiller - 09 Feb 2022 at 10:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 1:45pm
Only took me 5.5 HOURS to remove it....
good thing is NO bandaids.....
Have NO idea HOW to get it put back in though..
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 6:48pm
Congrats on getting the starter out! When we're retired, time isn't the biggest obstacle... it's being patient when we tackle these 'huff & puff' jobs. You can take comfort in the fact that you're well ahead of the 'book time' for doing this on a BMW car! We're looking forward to your post about getting the starter back in and everything working well again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2022 at 3:28pm
Got starter back ,next day...
.. new solenoid, new bendix, 4 new brushes ,good to go---$200 out the door
THAT was the deal of the day, worth get scared on the QEW with a very oversized load taking 3 of the 5 lanes(weeving) doing 120KMH aka 72 MPH.
and you wonder why 'truckers' get a bad rap ?
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 1:07pm
Wow that sounds dangerous to be on the same road as he waas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 1:34pm
same stretch of road the dump truck driver HIT the Burlington Bay Skyway bridge(dump trailer was UP !!!).
yeah, google that, read it, then reply when your head stops shaking !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 3:28pm
So Jay... for all the trouble you had getting the starter out, how long did it take to put it back in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 6:50am
Took about an hour. Normal ,healthy guy it'd be a 10 minute job. First it's heavy and I can't lean over, 2nd you NEED a 9/16,custom shallow MAGNETIC socket on a 1/4" drive setup,3rd, you REMOVE the air intake elbow 'adapter' FIRST....,4th..it'd be quicker if it didn't have the custom ABS PCV (blowby) system  to reattach...
Once everything was 'buttoned up', turn ign on,3 quirts of ether,pedal to metal, turn to start, vroom.....once warmed up, drove to garage to patch the patched tube in the right rear tire.Ongoing battle..no tires available, lousy innertubes. Actually thinking I could cut down a 5.8-12 tire use as a 'liner' between innertube and real tire.Naturally  I tossed 3 of them out last year cleaning up next door..
Oh well, she's next door,in the old D-14 #4 shed. So 'all is well'
