I600 Backhoe questions
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: I600 Backhoe questions
    Posted: 09 Feb 2022 at 8:20am
Is it 12 volt negative ground?
Does hoe and loader self contained?
Same carb, motor and drivetrain as D15?
I bid on one . I’ll know Saturday if I got it. Will need to drive it off property if possible. Been sitting a year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 10:12am
One more question?
Is it possible to remove and reinstall the hoe.
Sometimes I could use this at work in tight spaces without the hoe.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 6:56pm
Yes, you can remove the hoe, everything should be the same as a D15. Mine was a diesel and I can't remember if it was negative ground. Gassers were positive ground still, I think, at least the D14's were, but pay attention because many are converted to negative ground. Have fun if you get it!
