DA 385?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Topic: DA 385?
    Posted: 07 Feb 2022 at 8:41am
Of the the four planters here two are used yearly. In each of them the three wing nut used to hold and drive the plates what tool if any is used to loosen/tighten when changing plates. Is there a special socket or do we have to resort a hammer? I ask because I don’t have an owners manual and uncle bought his used and has always used a hammer. Certainly there is a better method?
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 4:03pm
It's been a few years since I had a 385 but I am certain I only hand tightened.
Might have used some channel lock pliers to break loose after setting a while.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 7:23pm
Keep using your hammer. That's why they are made that way.                 MACK
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 7:30pm
Do you want a owners manual? I've got an extra one that I could sell.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 8:02pm
We always used a flat washer against the plate like the 78 series.  I feel you are tightening the nut on the shaft due to rust or dirt build up on the threaded shaft rather than squeezing the plate against the cast flat washer that is driven by the roll pin.  Put some WD40 or other cleaner on the shaft and run the nut in all the way to the end of the threads a time or two to be sure. Yes ok to tap on the wings  but should not be necessary. The thing we are most concerned about on 385 is seed disc edge seal and makng sure we have a minimum of 2 water column inches of air pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 10:21pm
There is a flat washer between the nut and plate but didn't think of lubing the threads. I'm not a fan of using the hammer. I became a plumber cuz I couldn't make a living swinging a hammer. So I came up with this
I'm kind of a tool junkie so I made socket from scrap lying around and now can use a ratchet to turn the nut.
And yes, I would not mind having an owners manual.
Thanks to all for your help
Edited by plummerscarin - 07 Feb 2022 at 10:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 10:56pm
looks like a good idea
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2022 at 6:29pm
You made a - special tool - !  Just for this project ! Nice
