Rebuild WD with WD45 parts
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Topic: Rebuild WD with WD45 parts
    Posted: 23 Sep 2010 at 10:42am
Hi all!I am going to rebuild my WD engine and was thinking of using a WD45 kit.will this work or would i need a different crank etc?If it runs into allot of changes i will just use WD parts.Thanks for any help and advice.
Terry.
I couldn't repair your brakes, so I made your horn louder.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 12:11pm
Well the WD only has a 4 inch stroke
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 12:14pm
Terry - I'm no expert but if you want to build it as WD45 spec engine at 226 cu in you'll need the WD45 crank.  The 45 had a longer stroke (4" bore X 4.5 stroke) vs the WD's "square" 201 cu engine a (4" bore and 4" stroke).  Not sure of the other implications of piston height, compression ratio, etc. to use a WD45 kit in a WD engine if you don't change cranks.  Someone else will surely post that.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2010 at 2:18pm
You'll lose compression unless you get a 45 crank. You could put a 175 kit in it and your compression will be about the same as standard WD pistons but it won't be anything like a 45 engine.
Wink
I am a Russian Bot
