WD/ D15 industrial wheel swap |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: WD/ D15 industrial wheel swapPosted: 31 Jan 2022 at 7:16am |
Thank you
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 31 Jan 2022 at 7:05am |
the industrial may have lug bolts with a larger head. The bolt circle and pilot hole will be the same.
Thad in AR.
Posted: 31 Jan 2022 at 6:22am |
I’m seriously considering buying an I600 backhoe.
It’s sitting on some property way back in the woods with a bad tire. I’m wondering if I could use my WD45 wheels n tires to get it home.? Not sure if the bolt pattern is the same. I’m fairly sure a D15 and WD45 are the same but wondering if the industrial is the same? |
