Allis 614 forklift
hmontena View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmontena Quote  Post ReplyReply Direct Link To This Post Topic: Allis 614 forklift
    Posted: 30 Jan 2022 at 7:13am
Just found an  Allis614 forklift. It is in good shape, the motor is stuck, G160. I don't think I am going to rebuild it. I did find a 3.152 Perkins diesel Will it bolt up to trans or do I have to make an adapter plate ?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2022 at 8:22am
I would see if you can get the engine unstuck and see how it runs. Some engines unstick easy, some are tough. Depends on where they were sitting. Outside or inside, and whether it had spark plugs screwed in it or not. Ya never know. Sometimes they break loose with different formulas poured down the spark plug holes to get things loose again...
Steve@B&B
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2022 at 10:05am
Perkins will not bolt up.  You will need an adaptor plate to start with, and probably more fab work along the way.  Get the G160 freed up and you can rebuild it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2022 at 11:27am
If you find a G138 or G149 they would bolt right in and everything would fit in place, just be a little les power.
This page was generated in 0.107 seconds.
