Carpenters Square - what and how |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Thanks(2)
Topic: Carpenters Square - what and howPosted: 29 Jan 2022 at 11:57am |
https://www.youtube.com/watch?v=Ej1D5Bxqmjo&t=645s
Using a carpenters square - what the numbers are used for . Trueing a square |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 30 Jan 2022 at 6:37pm |
Thanks for sharing, Coke. I am definitely not on the top of my game in using squares. I picked up some good pointers from that video.
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2696 |
Posted: 31 Jan 2022 at 9:40am |
I learned in high school wood shop how to true a square and always check one before any project. Bet nobody that graduated in the last 20 can claim the same.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25254 |
Posted: 31 Jan 2022 at 10:43am |
I learned ,the hard way, that my 4' level wasn't level...... addition is still standing though after 35 years....
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 31 Jan 2022 at 11:13am |
I do S this video shows quite often but I always check the square with a 3-4-5 method if I find discrepancies.
Doesn’t take much of a hump or dip in material to throw the square off. |
Coke-in-MN
Posted: 31 Jan 2022 at 4:58pm |
Hot to bring it back to square was a tip I had not seen before , guess always felt it was a tool and would stay where needed - then seen a lot of them at garage sales = probably why - go buy a new one - give the problem to someone else .
3/4/5 is how I squared up excavations when digging footings or a basement - set up batten board corner 3 ft back from excavation and do measurements - depth became a one person job once I bought a laser transit = way back I used a optical transit but had story pole fitted with a 60p pole barn spike to hold it while I optically shot depth. |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 01 Feb 2022 at 5:55pm |
It must have been a STANLY level
![]() . Not sure when that brand took it in the diapers, but I will NEVER purchase a tool with the STANLY name on it !! |
shameless dude
Posted: 01 Feb 2022 at 11:05pm |
the combo squares is what i'm always checking, since the slider part wiggles when the nut is loosened, for short markings it's fine, but not for anything past about 2 inches.
