Oil drain pan
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Oil drain pan
    Posted: 26 Jan 2022 at 3:16pm
Just did a oil change and I need to replace my old drain pan . Just wonder what you fellas use ? Any recommendations? THANKS !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 3:21pm
Bottom 1/3 -1/4 of a 55 gal drum, plastic does work as well as steel and easier to cut handle holes in.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 4:42pm
I've had for many years a plastic can about the shape as a 5 gal
army gas can, but one side is pan shaped and drains into it, also has a screw on cap for easy dumping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 4:51pm
Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 5:58pm
Dollar Tree sells them - 1.25 @piece
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 6:03pm
Thanks , think I want one like Dusty has .
dee_veloper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 7:18pm
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2022 at 4:59am
To go along with several different common automotive type drain pans I have a couple plastic concrete mixing tubs and a 15 gallon water tub.
Not for drain pans, but related.  Those plastic rabbit/pet cage liner trays work good to throw down under something that is dripping, leaking, or during filter changes.  I have also used the large ones for containments under small engine driven equipment when required on projects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2022 at 1:54pm
Thanks , guys . That 16 quart FloTool pan looks like what I want . Home Depot didn't have any today . I have a 2' by 4' drip pan under my D 15 that I bought at NAPA . Guess I should see what they have . Thanks , again !
