Air fuel ratio gauge?
Mnesler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnesler Quote  Post ReplyReply Direct Link To This Post Topic: Air fuel ratio gauge?
    Posted: 24 Jan 2022 at 9:16pm
Just curious about using a air fuel ratio gauge for tuning a pulling tractor. Do many people you them or just tune using a dyno? Also are you looking for 14.7:1 or a little richer or leaner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 6:45am
I run EGT gauges on my pullers to keep the A/F in the ball park. It's work for me for close to 30 years.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 10:16am
We have one on a tractor they dont seem to
Last long. Like to be a little richer
What are the temp you like to see on your EGT gauge on a gas motor? PaulB.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnesler Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 1:05pm
What temps are you looking for? I assume cooler temps = richer
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 6:21pm
You are correct; cooler exhaust is richer, hotter is leaner. I only run E85 is my pullers with spark plugs which tends to run a bit cooler than gasolines. With that I try to be in the 700-800 range. For racing gasoline, I'd think around 900-1000.
