7010 head swap ? |
Post Reply ![]() |
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4543 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jan 2022 at 5:16pm |
My local independent tractor shop called today. They have a 7010 with a cracked head in for repair. It has the copper injector sleeves. Engine rebuilder guy suggested looking for the older style head. Has anyone done this swap? They know that the injector lines will be different. Will the injector pump work okay with either type of injectors ?
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5103 |
Pump and injection lines will work, but you will have to have the injectors reconfigured for the early style nozzle and nut. A 7010 may have AC holders, or may have Bosch/AmBosch holders. I'm not sure what all on the engine will need changed.
Kevin in WA ![]() Orange Level Access ![]() Joined: 08 Feb 2010 Location: Lynden, WA Points: 612 |
If i remember correctly, the injectors are the only thing you will need to change. I did this conversion to a 7000 , years ago.
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3531 |
Ed, many years ago I think it was Columbus diesel, had nuts for the two Bosh Inj that would allow for the changing of tips/nut or maybe just nut to allow swapping from the tapered nut to the flat style that used the copper washer for sealing in the non copper tube head. Then I tried again and they said they were discontinued - you have any sources for these?
Post Reply ![]() |
