Allis Chalmers B Gas Tank Valve
cfciii03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cfciii03 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B Gas Tank Valve
    Posted: 12 Jan 2022 at 7:48am
Rebuilding 1955 Allis Chalmers B and don't want to use a sediment bowl.  Any suggestions/pictures for an alternate 3/8 NPT valve ?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 8:39am
I rebuilt a CASE 530 12 years ago. Tank was rusty inside and i wanted to clean out over time..  I put a  pipe sticking down 6 inches with a cap on the bottom. 3 inches up i put a TEE  pointed toward the carb with a 3/8 brass ball valve in the line. Put a barb fitting after that with good inline filter, then hose to carb... We would pull the cap off the stand tube and drain out any CRUD every 8 hours, and changed the filter every couple months.. DId that for a few months, then OK since then.
Check the rating on the brass valve, but most are good for  water / oil / gas (propane) application... worked for us.
Edited by steve(ill) - 12 Jan 2022 at 8:42am
