Lift still won't lift.
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Topic: Lift still won't lift.
    Posted: 21 Sep 2010 at 10:37pm
I can't get the lift arms to lift on my new to me D17.  the remote cylinder works but the arms will not move.  I tried every thing I could think of and nothing worked.  I even drained the transmission to see if oil was leaking from the ram or the hose but nothing comes out of the drain hole when I cycle the hydraulics.  I was wondering if this tractor could have a selector valve?  Where is this located?  If this is not the case I am at a loss.  Any help will be GREATLY appreciated.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 10:48pm
The tractor is a series II snap coupler.  I tried messing with the transport valve but that did nothing.  My I&T shop manual talks about an optional selector valve.  I was wondering where this is located.  Maybe this is the problem.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 10:54pm
The hose that supplies oil for the internal lift cylinder probably has a hole in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 10:56pm
Would't oil run out of the transmission drain if the hose was leaking?  Trany oil drained and drain plug out.
tom (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 6:26am
Bypass the transport valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 6:59am
How do I do that?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 7:56pm
The lift arms on the 3 point on my D-10 series III would not work. I worked on quite a while before I found the problem. I found a needle valve, much like the ones on a carburetor put about 3 times larger.
Send me a PM with your e-mail address and I'll send you a picture from my parts book.
Might not be the same as yours.
I'm not very good at posting on here.
Dusty
