moniter
Ilikeallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ilikeallis Quote  Post ReplyReply Direct Link To This Post Topic: moniter
    Posted: 10 Jan 2022 at 10:44am
I have a moniter for allis 330 6 row air 78 units, that seems to flash all the time even when a chain broke on 1 row and i continued planting because it kept flashing, but then somrtimes it goes blank for a few seconds, open for suggestions, or opinions, thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2022 at 10:50am
while I don't know your equipment....
bad wiring and or connections would be my first 2 guesses.
gotta be a a fair bit of 'vibration' going on and that's always bad for connectors. Bend a wire enough times ,it'll break.
any water(? hehe) or chemicals, that WILL corrode wires, might not even see that happen
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2022 at 11:33am
Sounds like some serious 2-person testing is needed. Somehow turning each seed disc individually with seed in the hopper and fans running. Row #1 should align with Light #1 and so on. No other light should flash when testing one row at a time. There should be a beeper alarm when things quit planting, so it must not work either. Sounds like a harness issue to me. Dickey John made the monitor for A-C.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2022 at 11:10pm
hook all up, unplug all the units - drive around or at least wiggle the harness at all points. No light should be on or flash, then plug in one by one doing the same thing - should eliminate the harness or a sensor.  Another troubleshooting trick is to see what light is on - then swapping the row next to it to see if the problem follows the sensor or stays with the harness.
This page was generated in 0.130 seconds.
