remote start issue
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: remote start issue
    Posted: 04 Jan 2022 at 8:57am
New years eve, about midnight, son lets the dogs out, comes back in and says, your truck is running, all lit up, including trailer lights! Now, it is a second hand, 2005 f250. It has an aftermarket remote start, but I have never used it, the fob is in my desk drawer. I know the code can be copied when one uses the remote start feature, and then used to steal the vehicle.....but I never use the remote start.
I am at a loss to explain it.
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 9:58am
Many years ago as kids we would go riding around in the high class neighborhoods and open garage doors with the CB. You just had to get lucky and find what channel to use. After finding the right channel for an address we had a blast LOL Someone just got lucky with your code Thumbs Down Next time your truck may not be sitting in you driveway running Angry Remove it now before that happens
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 10:10am
Many years ago as kids we would go riding around in the high class neighborhoods and open garage doors with the CB. You just had to get lucky and find what channel to use. After finding the right channel for an address we had a blast LOL Someone just got lucky with your code Thumbs Down Next time your truck may not be sitting in you driveway running Angry Remove it now before that happens    but that is what is odd about this, I am rather rural, not too much around me. In any case, as you suggested, as soon as I can figure out how, I intend to disable that system
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 10:14am
You 'should' be able to simply unplug the 'box' from the wiring harness..once you find it ! Might be inside the driver's kickpanel or tierapped under the dash.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 10:42am
Did you feed it after midnight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 12:48pm
Grandkids and sticky fingers ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 12:51pm
Dont just YANK the box out as some of the wires may not just be tied INTO your truck wires... the original wire might be CUT and the box spliced in as a switch.. I had one and i cut a couple wires at a time and tried to start the truck with the key after each cut... Eventually found a wire that STOPPED the truck from starting... Found another wire to the box with SAME COLOR that needed to be connected together after the box wires were cut off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 1:14pm
Which truck ,gas ? should be able to find wiring for it ?
Which remote starter unit, again, can find install papers.
A truck that new , I suspect has a prewired connector for 'remote starter', especially if that was an option. Wife's 99 CRV was prewired/connectered for remst. 19 quashqi is.
Removing the remstarter box from truck wiring will quickly tell the story. NO damage can be done,providing ignition is not on.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 1:53pm
A couple of years ago a friends 20 ft overhead door to the shop was open when they woke upon a bitter cold and windy morning. They had some freeze damage to pressure washer and some pipes. They figure an airplane or something opened it as they live away from the road, They disabled the remote opener and only use the switches by the door so it wont happen again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 3:53pm
I appreciate all the suggestions. It's a 2005, w/aftermarket remote. no paperwork for it with truck. I do know what dealer sold the truck. I was going to see if they could advise. That failing, I will get the diagram and go from there.
Wait for the Lord;
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 4:15pm
Should shut itself off after 15 minutes.  No one should be able to drive it.  It's connected to the brake pedal and should shut off as soon as someone steps on the brake.  If you check the fuse box, you should be able to see any wires that were added, Just pull the wire off, or look for stray wires with a fuse in the wire and pull the fuse.  You'll need the FOB to try to start it whenever you disconnect something.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 4:34pm
Could be the batteries in the remote need to be replaced?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 6:28pm
Good luck Lou, I ran a '95 Dodge Ram with an aftermarket "keyless" start Confused. I never used it (used truck) and towards the end of the life of the truck, I had to unhook the battery AFTER parking and turning off the key switch only to have the starter engage and the power windows/locks jump up and down multiple times and found out there were multiple sources of power for the module Unhappy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 8:39pm
Lou, I hear that draining the blue outta the oval will disable it...Wink
