W patrol grader WC
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: W patrol grader WC
    Posted: 03 Jan 2022 at 9:08am
Hi, i bought a ‘48 styled WC rowcrop and it has no serial on the back. There is only WC on it with no number. On the right chassisbeam there is a plate with a number starting with IE. That would make it a grader. It also has a platform like a grader and backweels from a grader. In the front I can see with a light a (really good) weld were the rowcrop is placed on.
My question, is there any information if they did this maybe with unsold graders? So they could sell it as a tractor. Or would be don by a previous owner?
Thanks!
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 8:38am
I have seen pictures of tractors without the blade used for other things. No idea if they came from the factory this way. I have the circle, blade and hand wheels. If it were mine I would make a speed patrol.
http://lonsallischalmers.com
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 9:21am
Hi Lon, thanks for your reply. Do you sell te parts? I also would need the ‘long nose’ with frontwheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 10:06am
