WD45 Carb HELP |
devron30
Topic: WD45 Carb HELPPosted: 02 Jan 2022 at 8:02pm |
I have a WD45 and it cracked where the fuel line goes into the carburetor. I am looking for a new upper or whole carb. Where can I locate one. Thank you!
Albert
Posted: 02 Jan 2022 at 9:11pm |
Marvel or Zenith ? You have any numbers from your carburetor?
DrAllis
Posted: 02 Jan 2022 at 9:54pm |
The crack is from overtightening the elbow fitting. Depending on how bad it is, remove the fitting and have someone braze the crack shut. Reinstall the elbow with loctite on the threads and let cure overnite. I bet it can be fixed.
devron30
Posted: 02 Jan 2022 at 11:54pm |
It is a MS TSX-464
