Front Support Oil Level
Bruce Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Topic: Front Support Oil Level
    Posted: 21 Sep 2010 at 4:48pm
How does one check the lube level in the front support housing in a WD with a wide front? I sure don't see a check level plug.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 5:08pm
Worm gear is supposed to be "one third submerged". Use 140 gear lube for NFE and 250 gear lube for single wheel and WFE.
Of course if the lower seal is leaking (as many are) you may want to use a combination of 250 gear lube and chassis grease to help keep it up there whwere it belongs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 7:04pm
I used Mobil EP grease. It's a little less stiff than common grease gun stuff. Pack the bearings and add the rest of the tube + 1 more.
