Fiat Allis HD 11
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Topic: Fiat Allis HD 11
    Posted: 30 Dec 2021 at 1:49pm
What engine did they have ?
TIA
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 4:12pm
Not entirely certain but I believe a natural aspirated 10000 series Allis-Chalmers, or an 11000 series if turbocharged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:08pm
D-516 Lanova 6 cyl engines (Buda) in the early ones, then in 1963, AC 10000 direct injection (HD 11B) Later in the '60's, The HD11E had the 110000, the Turbo version.
The injection system was improved in the '70's.  Note all 3 of these engines are based on the block of the 516, with improvements added as the years progressed.Wink
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:55pm
A 6V-71 Detroit DieselBig smile
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 12:12am
Fiat Allis was formed in 1974
So I guess technically that brand name doesn't apply to prior models.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 11:10am
Fiat Allis had a 685T which is the metric 11000 same engine as an N7 less the intercooler
walnut1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walnut1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 9:00pm
I believe my 11B had an 11000 MKII? It had a Roosa-Master fuel pump, it was #16C-19201.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 4:06am
Weren't the early ones HD 11B and the ones around the Fiat Allis era HD 11 Series B?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 9:12am
https://contractormag.co.nz/classic-machines/allis-chalmers/hd-11-tractor/
Designed as a replacement for an earlier tractor, the Allis-Chalmers HD-11 was a very worthy successor and was in production for over 25 years.  By Richard Campbell
THE ALLIS-CHALMERS model HD-11 was introduced in 1955 as a replacement for the company’s model HD-9, which had been in production since 1950, and the earlier model HD-10, the 10-year production run of which began in 1940.
Both the HD-9 and HD-10 were powered by 71 series GM Detroit Diesels as at that stage, Allis-Chalmers did not manufacture its own diesel engines.
This all changed in 1953 when Allis-Chalmers bought the Buda Diesel Engine Company and began development of its own engines.
Allis-Chalmers introduced several new track type tractor designs in 1955, all powered by the “new” Allis-Chalmers diesel engines.
These included the HD-6HD-16HD-21 and the subject of our story, the HD-11.
Rather than just inserting a new powerplant into an existing chassis, the HD-11 was an all-new design from the ground up, utilising experience gleaned from the previous HD-9 and HD-10.
From the outset of track type tractor production, Allis-Chalmers had always been an innovator, developing many of the systems that have been incorrectly attributed to other manufacturers.
Items such as torque converter drive, permanently sealed rollers, power-boosted braking and even sealed and lubricated track (SALT) were all pioneered by Allis-Chalmers.
The first production version of the HD-11 was powered by a six-cylinder naturally aspirated A-C model D-516 engine which produced around 85 flywheel horsepower and had a six-speed direct drive transmission. Track gauge was 74 inches and the machine had a six-roller track frame.
A mid-sized tractor, weighing around 11 tons without attachments, the HD-11 was a contemporary of the Caterpillar D6International TD-15, Oliver OC-12 and Eimco 106.
By 1958, two improved versions of the original HD-11 were available, the HD-11E and HD-11B.
Primary differences were a change in engine to the new model A-C 10000 series diesel with a consequent rise in horsepower – 99 flywheel horsepower for the HD-11E and 111 flywheel horsepower for the HD-11B, seven roller track frames for each, and a torque converter drive transmission for the HD-11B.
These machines remained in production until 1962 when three new versions were introduced, the HD-11EC, HD-11EP, and an improved HD-11E.
All three were powered by an updated version of the A-C 10000 engine known as the A-C 11000 series which featured for the first time, a turbocharger.
All three machines featured different horsepower ratings.
The direct drive HD-11E was rated at 130 flywheel horsepower, the torque converter drive HD-11EC at 140 flywheel horsepower and the powershift HD-11EP at 150 flywheel horsepower.
Further changes included the addition of oil-cooled steering clutches and brakes, and a 6-roller track frame for all three machines.
In these configurations, all three remained in production until 1971 apart from the HD-11EC which was dropped in 1967 due to declining sales volumes for the torque converter drive/manual transmission type of tractor.
HD-11s saw service in the complete spectrum of earthmoving, agricultural and forestry applications where they were very popular.
In order to retain a competitive edge, Allis-Chalmers undertook a complete redesign of its track type tractor range and this revamp naturally included the HD-11.
Bearing little resemblance to its predecessors, the new HD-11 series B was introduced in the middle of 1971 in two versions, a powershift and a direct drive model.
Still featuring the A-C model 11000 turbocharged engine, the powershift version was rated at 140 flywheel horsepower and the direct drive model at 125 flywheel horsepower.
It was also around this time that Fiat, which had a substantial share holding in Allis-Chalmers, exercised its options and the company changed its name from Allis-Chalmers to Fiat-Allis.
Unfortunately, this was also to lead to the gradual decline of the brand as once Fiat’s influence began to take hold, sales in North America, the brand’s naturally biggest market, began to drop off drastically.
For the HD-11 series B, now known simply as the Fiat-Allis 11B, the writing was pretty much on the wall and the machine was discontinued in 1981, in favour of one of Fiat’s own models, the European-designed FD10.
Edited by steve(ill) - 02 Jan 2022 at 9:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote walnut1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 10:03am
The serial plate said Fiat/Allis 11-B as did the decals on the side. The manuals all said series B. No where was HD used that I can remember. I have two HD-11s tractors as well and the parts guy always referred to the newer one as the “square-nose B”.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 1:39pm
This is my 1975 build F-A 11B series tractor. 11000 series MkII engine:
This one is 25L19108 and no mention at all of Allis-Chalmers in any literature except the engine which is still identified as such.
Edited by Codger - 02 Jan 2022 at 1:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 1:47pm
Dang Codger that a sweet running machine ! Could almost smell the diesel smoke ; what do they weigh ?
Edited by DougG - 02 Jan 2022 at 1:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 2:23pm
This is a brochure I'd found online someplace several months ago. This tractor was not built with the limb risers but very soon after the purchase was discovered they were needed. A local welder installed these and I understand the tractor is just over 16 tons as seen.
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 7:54pm
Ok guys.....Here's an antique post you could check out....I was going to post some fresh pictures...but I was able to find this old post...besides the tractors look better in these old photoshttp://www.allischalmers.com/forum/new_reply_form.asp?TID=185432&PN=1&TR=13
    Ok...when you find the pictures of the 2 11B s....the ripper tractor weighs 40,200#....the winch tractor weighs 37,860#... Don't have a weight for the Grapple 11B that I can find.  The weights are very accurate...as we are able to weigh them on our truck scales.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 7:58pm
Ok... that didn't work out....guess I'm losing my touch....I'll try to bring up the old post'
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 8:02pm
Ok....This will explain the old post better
