Skidsteer tire
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: Skidsteer tire
    Posted: 29 Dec 2021 at 5:37pm
I have a flat on a skidsteer tire and the bead broke lose, What are some creative ways to air it up again
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 5:56pm
I'v had good luck jacking it up so the bead comes back out and take the valve core out so more volume of air goes in quicker. Good luck
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 6:01pm
Ratchet strap pulled tight around it helps with some tires. Skid steer tire may be too stiff though. Be worth a try
Edited by thendrix - 29 Dec 2021 at 6:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 6:04pm
ether and a match ? I'm NOT recommending it, just an old skool trucker way they did it....
smaller tires, like riders, I've strapped the center of the tread and tightend really good. It 'moves' the bead onto the rim.If radial tire, it 'should' be more flexible than biasply ??
use some form of 'bead sealer' goop. I use vbelt 'dressing'
besure bead is CLEAN and smoooooth of course.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 6:12pm
As thendrix said, chain and binder.  If you have a bead blaster, it does good, too.  Make sure to take some soapy water, and see if you can find the leak that started the whole problem.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 6:13pm
Did a skid steer tire last year using a ratchet strap over the tread. A lot of tires lately as a matter of fact. Took three to get the 4 rib back on the 7060. Also remove valve core for greater air volume. Be ready to loosen strap once the bead takes hold.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 6:18pm
I have used a ratchet strap with success. Tires on my Skid Loader now have sidewall protection which is thicker rubber on the sidewall. Starting Fluid and a long stemmed lighter worked. If you know of someone who has a Bead Cheetah tool which is a tank with a long pipe shaped on the end to insert air into the rim when a ball valve is opened. They work well on truck tires.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 6:48pm
I use a bead cheater often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 10:09pm
I've used great oil and bar oil to seal beads. Have also used dish soap. They all seem to work pretty good. Oil is a little messy though
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 10:14pm
Have used a lightly aired bicycle tube on 22.5 and 24.5 truck rims. Has to be small enough to fit inside rim edge. Lube everything up with veggy oil. Fills the gap where air is escaping. Remove quickly as bead will pinch and grab it.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 5:10am
I use rancid lard on the beads and a ratchet strap
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:17am
Renter got a new to them skid steer
Has the No Air tires, I would be seriously going that route these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 7:39am
No air tires are great for skidsteers in demolition work. Their down side is price when you need to replace and they don't ride very well. Foam filled is good but same high cost to replace. There is Company I saw an Ad for that makes a belt that lines the inside of the tire that prevents cuts and punctures like body armor. Never priced any so I don't know how pricey they are.Track Skid Loaders are great but pricey when replacing tracks. One Contractor I know put$7,000 in his Bobcat Machine for new tracks. He had a Dealer install. Probably could have done it himself cheaper if he had the place and time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 12:10pm
Ah yes - then there is the inner tube route - works every time on tires that de-bead more than once
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 5:07pm
CHEETAH!!! Thats the only thing that really works and its fast! --it will however knock you on your ars when you release the air valve!! LOL -- but seats the tires every time!
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 5:37pm
I'm curious to know where you guys are getting ETHER that does more than fizzle Stern Smile ??
The stuff in the '80's had some OOMPH, but lately from what's on the market I could light a fart and get a bigger bang Smile !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:11pm
Please do!  Oh, and be sure to post it on youtube!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:12pm
Freedguy,you need to do research on which Starting Fluid makes the biggest bang and report back to us.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:21pm
No intention on doing the "leg work". AutoZone/Advanced s/f only catches the sidewalls on fire-no BOOM !!
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:29pm
Hey captain obvious??? Spray it inside the tire,not on the side wall
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:29pm
I buy the 'ACE' brand, white can/red lettering in '50% more size, when on sale at Princess Auto. 2-3 small pffts and the forklift starts real good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:35pm
John Deere 80% either is the way to go !
Edited by DougG - 30 Dec 2021 at 6:45pm
bemer848 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bemer848 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 7:40pm
Freegas does not use youtube. He likes tictoc. Maybe he will post it there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 7:55pm
re: John Deere 80% either is the way to go !
figures,... that's all them green machines are good for,making smelly gas !
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 9:06pm
Finally home again. Guys please do not use either to air up your over the road truck tires. I have been to the DOT weigh station many many times demounting semi tires, blowing the either smell out of the tire and then remounting the tires. It gets darn cold out there this time of year especially after dark, when you are demounting 18 semi tires and remounting them. DOT considers them a fire hazard. As far as using either to mount combine tires, go for it but do it with caution. I had a good customer attempt to inflate a 30.5x32 on his Deere in the field. He tried either, a little didn't do it.   One can didn't do it. So he tried 3 cans. When he cane in Monday morning to have me go out and inflate the tire, he had second degree burns on all of his exposed skin. We had a 10 gal aluminum bead cheta one blast with that and the tire was on the rim. He had my home phone number, he could a called me. He said " I just didn't want to bother you on Sunday.".
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 1:44pm
Have seen some videos on ether tires exploding later on....not good . Was explained as to why and made sense. Never thought about it before...also never done it myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 4:02pm
Pyrolysis
Nasty effect!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 5:17pm
WELL , AREN'T YOU SPECIAL  ClapClap !!
Yet again an "expert " from the state of Missouri Confused
Have a Happy New Year jack hole LOL !!
Edited by FREEDGUY - 31 Dec 2021 at 5:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 6:43pm
How to win friends and influence people, gassy-style...LOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 11:44pm
Well guys I cleaned the bead and tire and took a old nylon strap put it around the tire tied it in a knot and put a breaker bar in the knot and twisted it until the bead went out hit the air and presto i removed the breaker bar and strap and aired up the tire.  Thanks for all the ideas.
This page was generated in 0.168 seconds.
