hd-7g question
davidneubuhr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidneubuhr Quote  Post ReplyReply Direct Link To This Post Topic: hd-7g question
    Posted: 26 Dec 2021 at 11:40am
Good day i have a question about the hd-7g crawler loader mine will pump all the oil out of the bottom of the transmission torque is spinning then quits all the oil is in the top of the transmission not returning to the bottom?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 6:36am
Filter strainer on face of transmission, directly under left foot.  Four 1/2" bolts and requires much of the associated hardware in that area be removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidneubuhr Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 11:42am
Thank you very much Happy New Year
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 7:06am
The trans pump first section draws from Trans Bottom Strainer feeds to the Left Brake Housing where this strainer sits to allow the pump to draw thru this strainer to feed the Converter and Trans clutches, the smooth hose nipple is the suction feed to the steering clutch pump under the injection pump.  The Aussie members that had dealt with these led me to this strainer.
Edited by DMiller - 01 Jan 2022 at 7:09am
HD6 Merv View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 11:12am
Yes that is half the problem with the HD6ep and HD7G ; you have  3 pumps feeding off one tit.
The other half of the transmission pump that feeds off the right hand side of transmission is only a scavenge pump to return excess oil from the transmission back to the steering clutch housing.
I always thought they would have been better if they had had seperate suction supplys for steering and transmission.
Am going to have a bit of a look at my old 6ep today, as is a steering issue for that i will have to sort at some stage. But she is at the back of my repair que as is it  more ornamental than a income earner !
tits tyres and tracks
they all cost you money
