Hydraulic pump for 180
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic pump for 180
    Posted: 21 Dec 2021 at 5:17pm
MY hydraulic pump has got tired after 60 years. My mechanic says with the aluminum case he doubts it will be rebuildable because of wear to the case. Anybody have any in sight to the best place to get a good pump at a reasonable price?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2021 at 5:42pm
Used to be able to get an A+I FOR $1200= 5 years ago , also should be good used ones out there
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2021 at 5:58pm
I love it when the repairman condemns the pump without tearing it apart. I can't think of one I ever threw away. Always FIXED what was wrong.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2021 at 6:23pm
Yeah Doc - unless it is not an oem, the wear sections are NOT aluminum.  The aluminum sections do have grooves for seals that can break and a careless blow can break them while replacing the needle brgs - other wise - .... almost as good as new with wear plates and brgs and seals.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2021 at 7:57am
sounds like a parts replacer mechanic!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2021 at 11:33am
There is seldom a problem with the pump housing. Replace the wear plates and seals.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2021 at 8:29pm
On some AC tractor models like the 220, the thin lip that supports the seal on one of the pump sections can crack and the seal will leak causing low hyd pressure on one of the hyd circuits such as steering.  If you just replace the seal without repairing or replacing that section then the new seal will fail, too.  Initially we thought we'd just find a used part, a parts guy had a couple used pumps with the same problem so we fixed the one we had.  My brother bored the cracked lip out, machined a steel insert to replace it, pressed it in, and machined it to the correct height.  It was a lot of work just to fix a weak point in the pump section.  An after market hyd pump was the next option.  They're too expensive to repair if you need shafts and gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2021 at 7:29am
I'd hope that the main relief valve has been ruled out as the culprit, instead of just assuming it's the pump itself. Was the pump flow-rated/tested for flow and pressure outputs ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2021 at 7:54am
Yes, The flow rate and pressure were check. It is only producing 1600# cold and drops to 1400# or less warm. The main pressure relief valve was pulled cleaned and rebuilt twice just to make sure it was ruled out and that got the readings up to where it is now. Before it was around 1000# cold. I was incorrect to call the pump 60 years old as it is an after market pump as it is not painted  orange and I can find no identification marks on the exposed side telling who the maker is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2021 at 8:20am
After-market?? or simply and Allis-Chalmers/Deutz-Allis/AGCO replacement pump?? A new pump is never painted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2021 at 9:19am
I'll look farther today and see if I can find any ID marks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2021 at 7:40pm
Take it off and put it in a box and UPS it to me. I'll tear it apart for free. I will assemble it fixed for an agreed to fee, but I have to see what the problem is first. P.M. me for a shipping address.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2021 at 8:08pm
The only lettering I could find is Wesster and at the drain return it says drain. And yes sir, That sounds like a deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2021 at 11:37pm
The original on my 220 had been run too long without being repaired. The groove for rubber backup had a notch ate through it.
This page was generated in 0.081 seconds.
