+ or -
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Topic: + or -
    Posted: 20 Sep 2010 at 10:08pm
Is a series II D17 diesel supposed to be positive or negative ground?  I have the factory generator.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 10:20pm
All D17s were positive ground.  I changed mine to negative though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 10:28pm
What do you have to do to change it over?  Or did you put an alternator on it?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 7:49am
Change wires on coil around. Hot wire from IGN switch to + on coil. From - on coil to DIST stud. Change battery cables to NEG ground. Then repolarize regulator by taking a short wire and jumping BAT to GEN. This is assuming you have kept the factory generator and not switch over to alternator. If you do switch it over to alternator you still do all of the stuff listed with the exception of repolarizing the voltage regulator.
Edited by DonDittmar - 21 Sep 2010 at 7:50am
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 10:35pm
Do as Don said, plus switch the wires on the ammeter guage.  I kept the generator on mine, just wanted it consistent for boosting other vehicles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 10:39pm
Thanks for the tips,  I want to do like DSeries 4 did.  Have it the same as everything else.
