The D series PD Light ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: The D series PD Light ??
    Posted: 19 Dec 2021 at 4:17pm
Were the D series the only series that offered that light (and I assume it was only on the series 3) ?? We ran a series 2 '17,'15,'19  and I ran a D14 for a neighboring dairy farmer and NONE of these units  had that light ??
Edited by FREEDGUY - 19 Dec 2021 at 5:46pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 7:33pm
where specifically is this PD Light located ?
G
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 8:02pm
Used on D17 Series 3 and 4.  Might be on D19, but not positive.  Definitely not used on smaller D series tractors.  It comes on when you put your foot on the clutch.
G
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2021 at 4:45am
Yes it is also on D-19 tractors. I have a gas and diesel model and they both have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2021 at 5:47pm
G
Thanks D for the info, to the later poster with multiple '19's , ours did not have the light or a knockout in the panel for a light as pictured Embarrassed
Seems like there was a "green" light on the dash of some D series tractors, what did that symbolize ?
Edited by FREEDGUY - 20 Dec 2021 at 5:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2021 at 7:00pm
FREEDGUY:  only 1 D series model used a green light.  That was the D21, it acted as a transmission fluid level indicator.  It stays on all the time when your trans oil is at an acceptable level.  No other D series tractor used a green light, although a few 100 models continued to use it - 200 and larger.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2021 at 2:17pm
Gee, I have never noticed the light come on with my series IV.  Maybe the bulb is burnt.  What is the purpose for it either on or off?
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2021 at 6:27pm
the pump in front of the PD sends oil to the filter on the rh side behind engine and located in the base is an on/off contact switch that relays the hyd system has oil and lube pressure to lube and cool the clutches.   Light is on when engine is off/key on, or foot clutch depressed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2021 at 5:19pm
Thanks for the information D Tongue !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2021 at 12:03pm
I have a Ser.IV D-17 and always wondered about this light. So if the filter starts to block flow the light will stay on.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2021 at 4:41pm
I have one on my I-400
