installing some trex patio flooring.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Topic: installing some trex patio flooring.
    Posted: 18 Dec 2021 at 6:43pm
i'm in southern AZ and the heat causes problems.   I wanna install new flooring on the patio; thought about using plastic underneath the flooring for a moisture barrier.   I think the plastic would desinagrate under the trex flooring.  I'm thinking about using tar paper under the trex for a moisture barrier.  I'm looking for opinions.  there will be a solid plywood floor under the trex!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 6:52pm
i dont think plastic under plywood would disintegrate... Think it has to be in direct sun light to have a problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 7:02pm
Be careful in choosing the product and the color. plastic lumber can act as a heat sink in sunny areas, and can broil your tootsies, if you walk barefoot on it!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 10:36pm
carpet lasts about 5yrs and it's not in direct sunlight!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 1:24am
prolly best to go with a slate type flooring? that's about all i've ever seen down there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 7:35am
lots of slate floors inside park models but in 5yrs of wintering here; i've never seen it on a deck!
RingGeneral View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RingGeneral Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 6:40am
Tar paper is actually a pretty solid choice under Trex in hot climates - it holds up better than plastic, which can definitely break down fast in that Arizona sun. Just make sure there's no trapped moisture between the plywood and the barrier. Also, if you're updating your whole patio, check out this website URL they've got some great outdoor sets that'd go nicely with new Trex flooring.
Edited by RingGeneral - 24 Apr 2025 at 2:06am
This page was generated in 0.840 seconds.
