D 15 sediment bowl
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 sediment bowl
    Posted: 18 Dec 2021 at 3:52pm
Pulled mine as I could see some rust/dirt in the bottom of the glass . Screen looks clean to me . Guess this crud is fine enough to go thru the screen ? Old gasket is rubber and I can't get it to seal . Do you fellas prefer cork or rubber ? THANKS !
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 4:09pm
Any time i have opened up a sediment bowl i  always put a new gasket in. Either one will work .  Have never been able to reuse a old gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 4:22pm
i bought a box of 6 rubber gaskets on e-bay for just a few $$.... Have used a couple so far.. Always good to have a couple setting around as spares.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 4:31pm
soak it in oil for a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 4:34pm
Thought I had a spare but it's not the same size . I'll get one soon . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 6:38pm
You can grind copper and steel pipes into 'gasket punches' and make your own, providing you KNOW where YOU put YOUR gasket material sheets....
..., I have NO idea where mine are hiding...sigh
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 8:32pm
Sounds like the sediment bowl is doing exactly what it is designed to do. Sediment/debris is stopped by the screen and has settled to the bottom along with any water. Screen doesn't have to be plugged to do the job.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2021 at 8:41pm
Agree with Doc. Fuel flows from the tank through the center of the fitting then up through the screen to carb line. Water and silt left to drop to the bottom of the bowl. As for leaking, dry fit the bowl to the base. If it rocks back and forth then the fitting is warped and sealing will be difficult even with a new gasket. BTDT
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 6:47am
If you can't get it to seal up, the main body of the sediment bowl has been warped by overtightening. There is a reason that the only have knurling or small bumps on the tightening nut. Pliers are not supposed to be used, however that is mostly want happens and why older ones don't seal up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 8:52am
Thanks for all the comments . Feel sure a new gasket will do the trick . I'll get one soon .
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 8:57am
When your putting the bowl back on, just as it's starting to seat, twist the bowl and that will help it to seat and seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 1:20pm
Looked thru my tractor parts boxes and found a new gasket that was the right size . Seems there's 2 different sizes ? Now if I can find a new one to buy and put in the tractor toolbox I'll be good . I have a clean and leak free sediment bowl now . THANKS for all the help everyone !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 1:23pm
do you have small short bowl or long bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 1:47pm
Not sure , I'd say it's a small and short bowl ? It's about 2" diameter and 1" tall .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 2:19pm
208362 is gasket for small bowl
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 3:33pm
Thanks Mike , is that a agco number ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 3:46pm
70208362 for ordering agco. Older D15 right
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 3:55pm
Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 4:19pm
the screen is 70235555
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 6:55pm
No answer to your question, but the WORST bowl to seal IMO was on the XT190 Unhappy.  On a different flip of the coin, I've removed/cleaned the bowl on the F2 countless times using the same gasket and never had an issue
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2021 at 8:55pm
The right one on a 190 isn't to bad but the left one is a real pain. I reuse mine many times. When I got the tractor I had to clean the bowl at least daily. It's the only tractor that sits outside. So I'm constantly drawing water from them. The cab is 6" to tall to fit thru the door.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2021 at 5:55pm
Sadly, it was the R/H bowl that gave grief, but I think there was another factor involved (dad). Ended up replacing the entire assembly as no gasket would seal Embarrassed. All is well since Smile.
