Ford Lug Bolt ?? |
Post Reply ![]() |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Dec 2021 at 5:31pm |
I run an '05 3/4 ton, my dad runs an '11 3/4 ton pick up. Today, a co-worker was showing off his new tires on his '11 Ford 3/4 ton van. His van only has 7 lug bolts
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8147 |
Probably both. I now vans are available in 1/2, and 3/4 ton versions.
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34283 |
Ford came out with that abortion long ago
Knew several guys bought light 3/4t trucks had seven lug wheels and nothing back then years ago as to aftermarket for them Edited by DMiller - 17 Dec 2021 at 8:26pm |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88421 |
YEP... a LIGHT DUTY 3/4 ton... Combination of a 1/2 ton with 3/4 ton axle parts with special hubs/ wheels. .......... only a few years.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24767 |
Had one of 'them' show up one day...man I counted the nuts several times, thought I needed new glasses.... dang silly.. course ONE of my '67 Mustangs was 4 bolt, the other 3 were 5 bolts........... Never ever understood WHY Cavaliers were 5 bolt, seems a waste of material and money...
JohnColo ![]() Orange Level ![]() ![]() Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Six cylinder Mustangs and Falcons had 4 bolts, V8's had 5 bolts, probably enough savings in brake parts to cover having two sizes, but still...
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
i'm with Jay...a fellow i know has a ferd pickup with the 7 lugs...had to count a few times myself, and when i asked him about it, he hadn't noticed either since buying the truck!
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
When ferx first came out with that, I had a guy working for me,a dang good little tire man, but his hair was a little thin on top. I walked by him and ask him where the eighth lug but was. He looked around for a while and them counted the bolts. He came over to me and made sure I knew the dang thing only had 7 lug bolts on each hub. I knew that, I was just thinking about him the other day. I havn't seen him since he went to work for Firestone. He was a good worker.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42018 |
Ahhh - but remember back when there were left and right handed lug nuts on vehicles and rims would not interchange like Buick and Olds because Buick had a alignment stud on the drum which other GM didn't have
Now it's offset (depth or rim) that has changed , or like my 73 Olds rims would fit my 65 Olds 442 but the early rims would not fit front of 73 because disc brakes would not fit inside the rim . |
Still remember the adage Righty Tighty Lefty Loosey EXCEPT on Chrysler and American motors, plus most ton and up Trucks lug nuts.
My co-workers van is a 2011 model year
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54373 |
Google can tell you...
1998 - 1999 they were called "F250 LIGHT DUTY"
2000 - 2008 they were called "F150 - 7700#" 2009-2014 they were called F150 Heavy Duty.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22101 |
The "7700" refers to 7700 lbs GVWRating versus 6250 lbs load rating on a std F-150. Heavier axles and brakes on the 7700 lb package.
any update, FreeGas ?
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
Question: were you looking at the hub cap or the actual wheels? Because Ford has a hub cap that has seven dummy lug nuts on it that they used on 3/4 trucks and vans? |
Post Reply ![]() |
