Dual 340 to big for 170 Allis? |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34623 |
Topic: Dual 340 to big for 170 Allis?Posted: 15 Dec 2021 at 7:14pm |
IS a Dual 340 loader to big for a 170 Allis? Just wondering if I should put it on. See it has a mid mount bracket, with front braces and extensions to rear axel. Don't want to bust the tractor in the middle.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 15 Dec 2021 at 8:40pm |
A lot depends on what you try to pick up. What size bucket? One item to remember is the front axle takes a lot of abuse from a front end loader!
shameless dude
Posted: 15 Dec 2021 at 11:56pm |
should handle it fine, and also what Klinemar says!
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 16 Dec 2021 at 3:28pm |
Good reason for a heavy counterweight on the rear hitch of any loader tractor
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 17 Dec 2021 at 10:48am |
Need to use the area between the ears for more than a place to set a hat.Front ends on any tractor can be overloaded.
A friend has backhoe so the rear is loaded plenty. Citydot begged the use of it, tested it to the max. Both front tires where old and blow, instead of other harder to fix things. So for safety load the back end but within reason. So if the back end is lite you know your overloaded. |
