Fixing hydraulic line leak
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Fixing hydraulic line leak
    Posted: 13 Dec 2021 at 9:57am
Ever since I put my 160 back together after a full engine and clutch rebuild, 2 of the power steering lines leak at the steering orbital where they connect. I have new compression rings coming this week. Other than a small cut off wheel, what’s the best way to remove the old ones without damaging the pipe?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 8:53pm
Tube cutter.  I do not recommend a cut off wheel for this job - the rough cut can leave filings which can circulate through the system and create more fun for you in the future.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 10:03pm
Are you saying they use ferrules on a steel line? I would thing a little tighter is the answer but you surely tried that. "Compression ring" leaves me scratching my head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 3:43am
Yes, ferrules according to the AGCO book. SLI had them in stock. I have tightened them to the point I’m afraid to go anymore. The orbiter is NLA. Pipe tube cutter is out of the question because I have no extra tubing to put a new ferrule on due to the bend at the nut. I don’t like leaks anywhere but this is worse than I will tolerate unless it’s not possible to resolve without causing further issues.
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 8:06am
make sure the ferrul is close to the end of the pipe if not the tube bottoms out before the ferrul gets tight and cause problems if that is the case you might try taking a little of the end of the pipe
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 12:24pm
This is my approach to removing ferrules:
I use a small hacksaw as they are easier to control and saw at a diagonal across the tube and ferrule. I do this as the tube has been slightly reduced in diameter at the ferrule location and cutting in line with tube you risk damage to the tube. a diagonal cut will help get more material cut out of the ferrule close to the tube. Do not cut all the way through but very thin. then use a screwdriver in the saw cut and twist to break the ferrule and slide off the tube. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 3:16pm
Sounds like a good approach. I haven’t removed the lines yet as they are a pain in butt to remove. I wanted to wait until the ferrules arrive to see what they are made of as I didn’t really pay that much attention to them during the install. Also a good point about maybe the pipe is slightly too long but I wouldn’t think they would have moved unless the ferrule has become loose on the pipe. Pipe is 1/2” in diameter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 7:46pm
Appears to be aluminum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 10:53pm
I've got my fingers crossed for you Rob.
What plummerscarin does with cutting the ferules off, that's the way I've done it also.  Like he says, DON'T cut through or you'll nip the pipe.  Don't ask how I know that one.....ConfusedEmbarrassed
Hopefully if you do nip it a bit, you'll have enough pipe that you can push it forward a 32nd and get the new ones on.  I used liquid steel on the one I cut through.  Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 6:00am
As others have said, use care.  A dremel tool with a cut off wheel is also handy, just keep a firm grip on the tool, and clamp the line to something, at a comfortable work level...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 6:13am
please, pretty please make 100% SURE you install them the right way ! 'bulge' to the end, I think.... maybe take picture of old BEFORE you remove.
This HAS to be a 'gotta have patience' job.
Also, toss the cellphone into theh house, far,far away from you !!!! If not, it'll 'go off' at the wrong time, scare the beejeebers outta you, and you'll be looking for 1) big box of bandaids ,2) an entire new PS hose and 3) new phone cause your's will be flying into the next county.
hope to see a 'success' replay soon, not too soon, take your time....
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 6:43am
Thanks everyone for your input. I’m on vacation next week and plan to tackle it then. Yes, patience for sure. Hopefully this will be the last time I will ever need to do this. New engine and clutches should last a long time so hopefully never have to bother these lines again. I will report back when this project is done. I think I will try the hacksaw approach since a power tool can cut quicker and possibly cause damage in the blink of an eye.
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 7:08am
Just some information since the lines are leaking and not the orbiter.  I replaced the orbiter on the 160 I had around 6 years ago since the top input seal was leaking on mine and rebuild was not possible.  Found the replacement available at a hydraulic/drivetrain company my brother works for and think the cost at that time was around $550-600.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 7:37pm
Thanks, I will write that info down hoping I will never need it. Good to have info like that just in case. Got this project done today, no more leaks! Now, my next leak to repair is the seals at the traction booster housing/lift arms. $130/side but they are still available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 7:40pm
AcFordhawk, can you pm the name of the company and the phone number so I can keep a record of it?
This page was generated in 0.120 seconds.
