Increacing horsepower on wd 45
gold642 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gold642 Quote  Post ReplyReply Direct Link To This Post Topic: Increacing horsepower on wd 45
    Posted: 20 Sep 2010 at 1:15pm
I have a gas wd 45 which i want to out plow a Minn moline ub diesel. I have a set of 3 -14 bottoms Allis mounted plows. My nephew has the ub and needs to be out plowed on plow day. He is pulling a set of 2-14 non mounted Oliver plows. I know the cubic inches is the same for the wd 45 170 175 and d17. What is the best ways to increase the 45 engine to the performance of the 170. I want the changes to be non obvious so turbos are out of the question. Thanks Ted
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 1:38pm
my first question would be what do you mean by 'out plow'? Are talking ground speed? Not spinning out? Fuel consumption? Acres per hour? I am not familer with the MM UB , my first suggestion would be to use as close of the same plow as possible. If speed is all your looking for  try to up the throttle on your tractor, set the plow to run shallow.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 1:47pm
You can take the center bottom off your plow and move the rear bottom up to the center position to make it a 2-14 plow.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 3:12pm
All you have to do is add about 80 cubic inches to the engine, the 5 inch stroke will help. Then add about 1/2 ton of weight to the 45 and you will be close as long as everything is balanced out right. Stock Minnie Moes would walk all over anything out there in the tractor pulls back in the 60's. Since he weighs more than you and is only pulling 2 bottoms, to even things out weight and horsepower wise you should have a 1 bottom 16 inch plow.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 4:00pm
snap coupler set up on a stock 45 has no problems pulling 3 14s around here in 3rd gear.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 4:11pm
You should be OK as you are.  You need a 2-14 mtd plow and add 500 lbs to rear wheels.  If both are stock you have more HP that the UB.  I have a 45 with 2-14's and can go (2)3.75 and (3)5 mph.  You need to get the plow adjusted properly.  I usually plow 8" deep.  So make sure he is plowing at same depth.  -  AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 5:54pm
Here's another way to out plow him. Mark off 2 sections of field being the same length and width with similar soil types . Now go plow and see who gets done first. You need a third party that knows what plowing is about for an impartial judge. If he plows at a proper speed to do a good job and you run in second gear he can't out plow you with a 2 bottom plow.
 Al, the UB has 283.7 cubic inches and rated at 46HP(tested ?),weighed 6000. The WD45 had 226 cubic inches and claimed 39 HP(tested 43)and weighed at 4000 give or take.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 6:22pm
Put a 1800 governor spring in it.
"Burgie"
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 6:26pm
Put a Barny taylor cam in it. He told me he sells alot of them to the plow days drivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 6:28pm
If you're up for modifying the engine, a set of 170 pistons from AGCO are like 8:1 compression. The OE WD45 is some where around 6.75:1. I was browsing my copy of the D17 parts manual and it lists D17LP pistons at 8.25:1. That would be another choice if they're still available. Use a 170 cam and carb and you should easily up the HP.
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 7:32pm
Brian if you change to a 170 cam dont you have to change the oil pump and whatelse??? And this Barny Taylor man whats a camshaft cost and how to contact him???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 7:41pm
ML Pankey is the guy to ask about getting in touch with him. All I know is they are custom grinds. Berry Cam Service in MN is another place to try for a custom cam. Far as I know, you don't have to change the oil pump. There was another thread a day or 2 ago that you can change your bypass oil filtering system to a full flow with a few modifications.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 7:50pm
why not just set and use the traction booster system on your WD45. most stock WD45's will play with a 3 bottom plow in most any type of ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 8:00am
17toy, he's wanting to "Out Plow" a MM UB. The UB had more HP and weighed 2000 lbs more than a 45 and the UB is pulling a 2 bottom plow. It's like apples and oranges.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 8:09am
you could let me be the judge.....
my Dad said the judges wore these(before my time)
Edited by bigfish_Oh - 21 Sep 2010 at 8:10am
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 8:49am
Make him plow with a 3x14 like you and you should have no problem out plowing him. I don't care that he has a few more ponies or a ton more weight. He will spin too much to beat you. Heard of and seen many time of 45's out plowing bigger tractors. Back in their day the dealers really liked to demo them til the competition quit showing up as I was told by the old AC mechanics I used to work with. By the late 60's you couldn't get the competition to show up at all to plow and be timed with a stop watch. Things switched to large demos of just showing how their outfits worked and not so much as a head to head competition.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 9:05am
Dad tells about Grandpa's 560(4-14) and the neighbors 730(4-14) and D17(3 bottom) in the same field(when new) I always ask him, how many weights were on the D17, tires loaded? The 17 was always the first to leave field when wet. I have to assume it was never heavy enough or set up correct. As it got slippery he remembers that thumping coming up behind him, then he had to quit, the 730 was slower but still plowed when traction was needed.
    My other Grandpa sent home the JD dealer with his new 3020 4010? when my 45 plowed what it wouldn't. The dealer was after him for weeks to let him show it, he finally said if he could plow this field better than the 45 he would buy it. He knew it would not be set up right and it was a tough field.
2014 HD Tri Glide
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 4:09pm
A UB moline weghed 6050 lbs was on 13/38 rubber and had 46 pto hp at 283 ci . you get the 13/38 tires and 283 ci  weight up to 6000+ lbs and you will out plow a ub.
richneu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote richneu Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 4:28pm
Interesting confrontation or plowing contest. A contest would normally be who would plow x amount of acres the fastest, no matter what size plows you used, otherwise how would you judge it.
Several years ago in Europe a 225hp Massey Ferguson pulling 13 plows in the back and 4 plows in the front plowed about 640 acres in 24hrs. Many larger tractors were there from many manufacturers and could not even come close, they were fueling on the go and moving very fast when the going was easy. The variable speed transmission kept the tractor at optimum pulling power.
I would not count out a WD-45 with loaded tires, maybe extra wheel weight and the mounted plow.  Yes a newer governor spring could help from a D17 or 170 I believe. It would give faster speeds and power from lower gears.
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 4:35pm
all you need to do is get a set of 2 bottom 14" plows and set the depth as deep as it will go and you will out plow him, I do it all the time with my 45 it will be faster and plow deeper than most guys do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote richneu Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 5:15pm
The mounted versus unmounted/trailed  plow can easily translate to a difference of tractor weight 1500-2000lbs. The old Ford N's  selling point was a mounted draft controlled plow and they could keep up to a Farmall H that was heavier by 1500-2000 lbs. Plowing is a kin to tractor pulling, balancing the weight control means a lot. Our TO-20 Furguson could  pull a mounted 2-16 with no wheel slip in clover loam ground and it did not have any weight added.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gold642 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 6:00pm
Thanks for all your ideas. The contest is acres per hour at 6 inches plow depth. I own the land so I can pick the field. I have clay and sandy soil. What do I want? I like the idea of the 2 bottom on the wd 45 as I really want to lap him in the field. I have a 2-14 allis plow from my wd so that is no problem. I am not limited by a budget . If I need to put 2 or 3 thousand in the engine I am good with it. Therfore rebuilding the 45 into a 170 is no problem if the parts fit. I have read the d17 and 170 motors use different bearings. I don't know if there is a difference in the heads. Is the compression difference changed by the pistons only like in the super m's and h's or is there a difference in the heads.I read the carberator on a wd 45 is 1 inch while a 170 and d17 is 1 and 1/8 inches bore.  Where do I get the power cam at? Any one have an address. Remember unlike tractor pulling I need to be able to do this for hours and not look modified. I was planning to liquid load the front and rear tires. If I need to I'll put a front loader on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 6:13pm
they are some suttle differences in a true wd 45 head and a true d17 head mainly plug hole depth .  I think you can  make 85 to 90 hp out of a 240 to 260 ci and not be radicle or any components outside that would be noticable . move the cross arm hole up 1 inch use a 175 spring lighten the wieights up some add a gov . bypass when need a little more rs  compression and massage the head and use a bigger carb  . different valve to help head flow.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 6:28pm
Get some farmall H connecting rods, etc,   Lord ,here we go again..........  Got  to win ,money is no object?   IF your  wd45 has a good number on the dyno now, good rubber, loaded tires and a few added wheelweights and a properly set up plow you are gonna smoke him in acres per hour.  3-14's in 3rd gear with a traction booster is all you need . Insist that he pull 3-14's and  have at it.  My .$.02
Post Options Post Options   Thanks (0) Thanks(0)   Quote gold642 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 7:31pm
mlpankey, Can I use liners and pistons from a 170 in my wd45. How about gaskets? Are the bearings different? What would you use there. I can take the head to a speed shop and tell they to do the best to enlarge the valves and do the head so they flow better. I will order the 175 governor spring. I can order a 170 carburetor. I can contact berry cam to grind a cam. Any ideas here? Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote gold642 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 7:42pm
Gary, He is going to demand he uses his 2-14 Oliver plow. I have always said Allis made some of the best tractors made. I know he has the governor spring and pump cranked up . However he never rebuilt the motor. The rpm and additional fuel will help him. I know he has a real advantage in weight and horsepower. However I believe the mounted plows will expose his traction weakness. Besides, I would hate to have to use my 1932 Allis L crawler to defeat him. Ted
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 8:30pm
If he didn't rebuild and build up the engine then turning the fuel up doesn't do much and can actually hurt him pretty easily. If your current engine is healthy I wouldn't bother with an overhaul and even if you do overhaul I wouldn't bother spending a lot to hop it up. Your tractors transmission would appreciate it. You'd be better off finding a good scouring 3x14 or 3x16 plow and do a little practice plowing and make sure it is set up right and that your traction booster is in working order. That will get you further ahead than anything. A 80 HP WD45 will embarrass you as you drag it's locked up rear end out of the field. It's not the same as pulling for a minute down a slippery track. Get a good plow and get it set up and make sure he has the same size plow. No matter how well he is set up you'll out do him.
Wink
I am a Russian Bot
BillyL(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyL(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 9:55pm
I am confused. If the contest is acres per hour at 6 in depth let him run a 2-14. If he runs as fast as he can go and stay on the seat and you pull a 3-14 in third gear you are still turning 50% more dirt with each pass. He will have to make 3 passes to every 2 you make to turn the same amount of dirt. So he should lose more time turning than you will as well. Now if it were just a drag race it would be a different story. I would think the UB would pull a 2-14 6 inches deep at full speed road gear in concrete if he wanted to. But that's just my opinion. Something you might want to check is how much fuel each tractor uses. I bet there will be a big difference.Billy
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 11:49pm
I am pretty sure It was plowing in a circle also
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 7:50am
Garry its true I believe there is never to much hp.  Yes the 170 ,175 sleeves and pistons will fit . pistons and sleeves have no bearings to be a issue.   I wasnt thinking of using a 8 inch rod in the motor as garry thought I was thinking about . I was thinking alot on details in the head as valves and valve train . smoother radius turns toward  the intake valve etc. I wouldnt get wild with the exhaust valve and port on a small bore size engine .
Edited by mlpankey - 22 Sep 2010 at 8:00am
