WD headlight pigtail wire
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: WD headlight pigtail wire
    Posted: 04 Dec 2021 at 9:24pm
My WD headlights and lenses are in fine condition except for the pigtail wire.  In other words the end piece that connects to the bulb and then end of the wire.  Do they make replacment pigtail wires only?  If not, what are people doing  just using electrical tape from end to end?  Thanks in advance for any thoughts.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 7:25am
Take bulb out pigtail will push out just pull wire the rest of the way out solder disk on end to new wire and feed back thru
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 9:32am
I got mine at NAPA
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 10:29am
NAPA part number LS6226 is the single contact lead with the spring  and 2 fiber insulating washers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 2:16pm
This is just the best forum that was ever created.  I have to make a NAPA run next weekend.  I especially appreciate the part number, that really helps. Sometimes you get a new hire who can't find anything, so this will help direct them.   You are all the best!  Thanks again!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 6:13pm
You can get just the little button as well as all the other parts like that from the Brillman Co. www.brillman.com Then use the color wire of your choice to match it with the original wiring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 6:27pm
If you visit our website we offer a repair circuit kit to repair the WD/WD45 Headlight pigtails. You can use our kit 1504-03A which replaces all of the Headlight circuit wiring, or we can sell you just the pigtails that go down each Headlight tube.. Your choice.
Steve@B&B
bb-customcircuits.com
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 9:33am
I’ve just solder them.
Normally the wire is shot and the pigtail is still good with all of them I’ve worked with.
