Help Fixing D17 IV - Melrose, WI
Greg_WJP_(WI) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Help Fixing D17 IV - Melrose, WI
    Posted: 02 Dec 2021 at 9:12am
I'm looking for someone to help me get my D17 IV running, again.  The tractor is located in the Melrose, WI (54642) area.  I'm hoping that there is someone relatively close that is looking for something to do over the winter.  I've given up trying to fool myself, thinking I'll be able to do it.
What I'm looking to have done:
1. Get the tractor running
2. Install the 2nd set of remotes (I have the parts...or at least that is what I was told)
Transportation
1. The tractor has a loader and filled rear tires.
2. I am unable to transport it, so I would need assistance with that, as well.
3. The tractor is not located where I live so there will have to be some coordination on transport; meaning most likely on the weekend.
Backstory
A couple of years ago I tried to install a second set of remotes, but I ran into an issue with disconnecting the hydraulic connections under the deck.  I spent several months travelling back and forth applying a variety of products to loosen the connections, but could not get them free.  Eventually I gave up and reassembled everything.  Afterwards, however, the tractor failed to start, which has now been a couple of years.  The tractor has always been shedded.
Thanks,
Greg
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 4:14pm
I m in Farley iowa, We can get you going, Call or text 563 542 0673
phil
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 9:29pm
I'm about an hour west of you just across the river in MN. Could probably help you out if you're interested. Private message me on here if so.   Thanks
This page was generated in 0.191 seconds.
