B/C distributor wanted.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Topic: B/C distributor wanted.
    Posted: 02 Dec 2021 at 6:54am
Anybody got a junk B/C engine with a distributor?
Need the whole works, including the governor, as I'm switching from a magneto if I can.
Tractor I have is basically a junker that i'm trying to make run and see if it's worth fixing up.
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 2:05pm
Might be cheaper to fix the magneto than swap everything. If you post on the forum w symptoms may be able to repair quick er and cheaper
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 3:40pm
What you are looking for will not be from a C as it was only used on the later Bs and CAs. However you could find the aftermarket distributer conversion and just get a new magneto governor.  With a distributer you can go with an electronic ignition conversion and never have any further problems if installed correctly.
   Magnetos are fine if totally rebuilt by someone that knows what they are doing and work best when used regularly. It seems most problems with the happen to tractor that are stored for long periods without being run.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 5:55pm
I’ve got one, text me if interested. 404-358-2635
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2021 at 6:09pm
We offer a Mag to Distributor conversion kit if interested. Check out the website
Steve@B&B
bb-customcircuits.com
