Dr. Allis
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: Dr. Allis
    Posted: 20 Sep 2010 at 8:10am
Is there any way to put a 11 inch clutch likes in a d17 in a wd ? I need to be able to hold road gear bad in the light open gear classes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 8:15am
I doubt if there's room diameter-wise. Just move your throwout brg back 3/4" or so and add a second clutch disc and floater plate to yours....it will double the holding power. Use the same pressure plate and make a spacer to move it back from original position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:12am
ok I well contact you for a little more insight. thanks dr.
This page was generated in 0.095 seconds.
