Axle temp sending unit
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Axle temp sending unit
    Posted: 30 Nov 2021 at 8:41pm
The electrical wire blade connector broke off of the axle temp sending unit. The center terminal is still good. Can I run a ground to that wire that’s supposed to plug into that blade, and thus the gauge should work, correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2021 at 12:23am
Only if you want full sweep of that gauge all the time.  Temp Senders are a variable resistance based against a temperature range not a hard ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2021 at 5:05am
This one is a two wire sending unit. It has the blade terminal(which is broke off), and the threaded stud(which is good).
Was hoping my idea would work, to get by until the next scheduled PM. Then I would change out the sender.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2021 at 6:31am
as a temporary bodge...
take an ohmeter and measure the sensor...probably +-150 ohms ? maybe 100, 250,?
something in that region.
buy a resistor at radioshack(do they still exist ??) and connect to the sensor wire and ground.
this will give a fixed temperature and NOT indicate an overheated axle...
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2021 at 6:44am
No.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2021 at 10:03am
with that little better explanation yes your plan should work. The spade should be a redundant ground for the sensor since it is not directly grounded through the chassis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2021 at 6:27pm
Missed the two terminal part, Yes adding a ground at times helps.
