Please Help with AC 170
Eastland AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eastland AC Quote  Post ReplyReply Direct Link To This Post Topic: Please Help with AC 170
    Posted: 19 Sep 2010 at 10:25pm
My FIL's AC 170 has what we believe an issue with the fan.  After running for only 15-20mins the fan starts to run at an irregular pace.  Slow than fast with no particular pattern.  Any suggestions on where to start looking for a solution would be greatly appreciated.  Also, is it worth buying the service manual off the internet?  I found places where you could buy them or download them.  Obviously I am not mechanically inclined due to my description of the issue above, so I appreciate all feedback and advice.  Thanks for taking the time to read my post.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 11:32pm
The fan is belt driven - make sure the belt is in good condition and has proper tension on it.  You might also want to check the water pump shaft (which the fit mounts to) for excessive play - movement front to back of tractor.  If it's worn, replace the water pump.  There is not really much else to check for a mechanically driven fan like this.
Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eastland AC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:57am
DSeries,
Thanks for the advice.  I appreciate it.  We'll start looking there.  Does anyone have a parts department they recommend?
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 7:32pm
Sandy Lake Implement. They are a sponsor on this site and their service is first rate.
