Vehicle Led Rope Lighting ?? |
Post Reply ![]() |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Nov 2021 at 5:24pm |
I've been seeing more and more vehicles (2 years old and newer) with the front "parking light" area made out of a ribbon of LED rope lights that half or ALL of the section are dark. What's the fix for this ?? It's all brands of buggies, not knocking any particular manufacturer
fixer1958 ![]() Orange Level ![]() ![]() Joined: 13 Feb 2010 Location: kansas Points: 2434 |
Are you talking about 'Halo' lights. Something like you describe. Nothing new really if they are that unless it is different in your area.
No, it's the wavy "rope" lights that go 2/3's around the headlight bezel, on luxury cars, SUV's and Urban Cowboy P/U's. The "halo" Imo is on Jeeps that I've seen. Thanks
Well alrighty then, I digress. Sorry to interrupt the mind bogglingpondering things that people spend there money on. Are you the guy that calls into Mr Obvious on Bob and Tom?
Sounds familiar.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88237 |
i doubt every new car you see has aftermarket rope lights..... i think Fixer is probably right... all new cars / trucks have "halo" systems... which looks like a string of lights around the headlight.
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34197 |
Not rope lights
Fixed in place LEDs for daytime driving lights, swap when turn signal is used to yellow from white on most versions. |
rope lights are what the kids stick to the bottom of their bumper or running boards to light up the pavement below them...
[QUOTE=fixer1958]Well alrighty then, I digress. Sorry to interrupt the mind bogglingpondering things that people spend there money on. Are you the guy that calls into Mr Obvious on Bob and Tom?
Sounds familiar. [/QUOTEMy mistake, the "halo" light to me was what the off-roaders (or want-to-be's) were putting on the grill assemblies of Jeeps for aftermarket led headlights ; pinks,greens,purples. They never get the headlights dialed in correctly either, BLINDINGLY bright in the day light even on low beams
Walker ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: oh Points: 8983 |
They have to put something on there to make it look worth 20-50 grand.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3951 |
I find them extremely annoying in the rear view mirrors. Have taken to hugging the center line to keep them out of sight on the side mirror
Halo lighting is the current "NEW" trend, as noted to make it look or appear worth more, still NOT.
95% of all current Auto lighting is LED, takes Special equipment to make T/S or Flashers function the lo-load lighting where Adding MORE LEDs to that string makes the equipment work 'better'. Spoke to a tech at GM, was changing out my Warranty Seat Air Bag Sensor, as to the new flasher equipment. He stated if T/S fail it requires a $435 module replacement (often warranty but not always) with close to six hours labor to disassemble/reassemble the dash to access it. Freightliner/Western Star and PACCAR trucks all have similar set up mechanisms, a Frt Lnr SAM Module is $1460, drives EVERYTHING from start circuit to w/s wipers and electric door windows, EVERYTHING with a electric switch on Dash. Failure rate is 10-20% of all trucks with them will experience one or more failures of them in five years or less, after five years failure rate increase exponentially for corrosion and moisture intrusion. Mounted OUTSIDE cab on Firewall.
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Fixer, you nailed it as that is about the best description I've heard!
One of the best things about The Bob and Tom show in their heyday was Chuck during "Mr. Obvious taking calls". That and everyone piling on Christy Lee, that girl was constantly "in the barrel". Yup, "Mr. Obvious" fits this guy to a tee; anyone that has not heard those bits from the old B&T Show will surely get a chuckle when you pull up those clips . . . . .
LOVED B&T in the day!!
Thanks for the reply, I was envisioning popping the hood and pulling out "dead" bulbs in the grill area,IF it was accessible ![]() Yes, I forgot about the 18 wheelers that have that "lighting" set-up
![]() Edited by FREEDGUY - 27 Nov 2021 at 6:22pm |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Grandson spent a couple of hours installing rope lights under his Dakota. They lasted about 48 hours before the gravel roads destroyed them.
Post Reply ![]() |
