10% off Nelson mufflers |
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Topic: 10% off Nelson mufflersPosted: 25 Nov 2021 at 1:35pm |
SMALL BUSINESS SATURDAY SALE phone # is 920-598-1287, email is parts@awtractor.com Will be open Sat 9am to 7pm #233450 fits vertical mufflers on B, C, CA, D10 <serial #9001, D12 <serial #9001, D14, D15 series I gas tractors #248883 fits 180, 185 gas/diesel, also fits 170/175 diesel & D19 gas tractors #237811 fits D15 series II gas, I-60 gas, I-600 gas, 615 gas tractors #249324 fits 170 gas, 175 gas tractors ![]() Edited by Alex09(WI) - 25 Nov 2021 at 1:37pm |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 25 Nov 2021 at 9:13pm |
Does the #249324 also fit a D-17 Series 4 gas?
Randy WI
Joined: 22 Jan 2014 Location: Ogema, WI Points: 863 |
Posted: 26 Nov 2021 at 7:51am |
Alex do you have a simple trick to get the bolt holding the muffler on mine is rusted solid on my D14 would like a nelson muffler on but fear breaking the bolt off hoping for an easy fix. Randy
Alex09(WI)
Posted: 26 Nov 2021 at 10:37am |
It does, only difference is outlet pipe is twice as tall and 1/4" larger (1 7/8") than D17 muffler 246129
www.awtractor.com
Alex09(WI)
Posted: 26 Nov 2021 at 10:49am |
No easy way, penetrating oil or/and heat. Or break it off and drill it out (reverse drill bits work best) and retap threads. The NOS bolts I have here are grade 2 so easy to drill and retap! If your threads are 3/8, you could go with the brass bolt 226169 from WD45 muffler, but the D14/D15 parts books seem to show a 7/16" bolt used to attach muffler... Contradicts the used D15 manifold I have here which is threaded for 3/8" bolts.
www.awtractor.com
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4284 |
Posted: 26 Nov 2021 at 8:00pm |
Alex, do you have any for WD's/45's?
Alex09(WI)
Posted: 26 Nov 2021 at 8:13pm |
Nope, but expecting more any day now.
www.awtractor.com
IBWD MIke
Posted: 27 Nov 2021 at 7:55am |
Thanks Alex.
ORBill
Posted: 27 Nov 2021 at 10:53am |
Alex
PM sent Bill
john(MI)
Posted: 01 Dec 2021 at 6:36pm |
Heat the bolt with a torch until red, then toss a glass of water on it. Don't overheat the bolt until it starts dripping! This worked well on my D14 manifold bolts and I highly recommend it. It appears that this process separates the metals back to their separate materials. |
