3 position switch wiring question
AC Tundra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Tundra Quote  Post ReplyReply Direct Link To This Post Topic: 3 position switch wiring question
    Posted: 19 Sep 2010 at 7:31pm
I just want to confirm that the wire from the generator (Field) goes to the terminal on the resister , the wire for lights goes to the terminal on the fuse, and the other terminal on the switch goes to the amp gauge.
Thanks
What do you mean another tractor, honey? That tractor has been here for years.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 9:00pm
You are correct about the field wire going to the resistor, but the wire from the amp gauge goes onto the fuse and the light are connected to the  switch at, i think, screw terminal S, if I remember correctly,
Bob
