Allis Chalmers HD6 in NZ
Valiant Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers HD6 in NZ
    Posted: 19 Nov 2021 at 2:29pm
Hi all,
We are moving onto a property that has an abandoned HD6, apparently was used for logging, something broke down, he went bankrupt, and walked away and left it. Apparently it was running 5 years ago, and when we looked at it the muffler was half full of water. I haven't even looked at it a second time, but I am wanting to see what is up with it. I don't want to put a lot of money in the engine only to find out hat the tranny has blown etc, as I've been bitten before in a situation where I had to rebuild the engine before I found out that the rear end (hydraulics gearbox) was only worth parts. Are there any parts or donor engines/ parts available in New Zealand? It has the HD-344. Alt is there a readily available engine that would bolt straight in?
Thanks,
Valiant
Edited by Valiant Farmer - 19 Nov 2021 at 4:31pm
PSALM 119:105 : Thy word is a lamp unto my feet, and a light unto my path.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2021 at 11:49pm
I had several of them. I never had 1 set that low in the front. Would guess the front spring is broken. Please post the serial number. The later ones had heavier crankshaft and other bottom end parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2021 at 12:56am
Engine # 87657. I don't have access to it for a while. Thanks
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2021 at 5:05am
This HD6 have a BUDA ALLIS CHALMER motor 344 and yes the spring must be broken
