WD camshaft
hertter33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hertter33 Quote  Post ReplyReply Direct Link To This Post Topic: WD camshaft
    Posted: 18 Nov 2021 at 9:04pm
I see post about using a 175 AC cam as a core to have ground for a WD.  What is the advantage to using the 175 cam as the core instead of just using the WD camshaft?
Also is there any advantage to the tall head vs. the short head?
Edited by hertter33 - 18 Nov 2021 at 9:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 9:12pm
Not using a 175 cam as a core. Grinding a WC-WD-WD45-D17 cam to 175 cam grind profile.  Tall head has spark plug more centrally located. Might flow a little better too, but I can't imagine it would be a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hertter33 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 9:31pm
OK.  I misunderstood the camshaft thing. Thank you
This page was generated in 0.083 seconds.
