Transmission Oil Selection
NorthState Machine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthState Machine Quote  Post ReplyReply Direct Link To This Post Topic: Transmission Oil Selection
    Posted: 16 Nov 2021 at 9:43am
Hello All,
Quick question for the group:
1965 Fiat Allis 545 Wheel Loader- has an Allison Torqmatic Transmission TT2220-1
Would anyone know what this "should" take for fluid? I've heard Dextron ATF, to 10W, to 15-40? Seems like when i ask the local shops too, there seems to be differences there as well; I was leaning to the 15-40 personally-but just want to make sure i dont hurt it by putting the wrong fluid in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2021 at 9:53am
A variety of oils will work... Some use Dextron, some use 10wt hyd, some use 15-40 engine oil... thicker oil can help on older trans with internal wear...
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthState Machine Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2021 at 2:38pm
Thank you Steve! Much appreciated, I guess there seems to be a lot of folks using different oils, but that must mean it's not as critical as I was worried about.
