Valuing an IB
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Valuing an IB
    Posted: 14 Nov 2021 at 12:45pm
Pricing a rough ib.
I am interested in a 1946 (correction - its a 1950s model) ib. It runs, but smokes massively once warmed up - incomplete air cleaner in dirty environment likely wore out cylinders. Some antifreeze (pancake batter) in engine oil.   Mag ignition. No wiring. Generator swapped for alternator. Missing foot throttle linkage. Both rear hubs have some slop on axles (unlikely from loose axle nuts). Kept outside many years - trans has rain water in it. Rad is good. Tin is good and inl fenders. No battery or battery box. Tires are old, but lots of tread. No hitch or drawbar. No implements/snow plow. In/exhaust manifolds are good.
I offered $900, but was turned down. Did I offer too much, just right, or too little?
Edited by KMAG - 04 Dec 2021 at 8:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 1:03pm
way too much, I'd have offered $500, even then that's being generous.....
..sounds like it needs  a TOTAL teardown/rebuild..bet that's close to $2000 in REAL new parts.(be interesting to hear what others say !!)...then there's the missing stuff...is it EASY to get or scarcer then hen's teeth ??
yes, it's an IB but... lots were made, so unless you really,really just gotta have it....
call again, week before Christmas, ask if t's still there. if so, say  'I got $750 cash......
see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 1:07pm
You could spend 3x that on a good working machine and be money ahead without the hassle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 3:21pm
If needed I have a few original B/C air cleaners available.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 3:48pm
I agree with jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 4:19pm
$500. would buy a running B with some problems, but not an IB... If you want it, its probably closer to $1500. .... yea, your going to put that much more into it, but are you looking for a finished running tractor, or a project ?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 8:02pm
$500 at most!  You are looking at a total restoration there.  The only good stuff is the sheet metal.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 8:54pm
It depends on how much you want an IB. They are neet to have as there were not that many made but there were a lot of Bs made.
I paid 2000 for mine but mine came with an enclosed cab and a snow plow which is very unusual. You will never make money by restoring tractors, but then it is a hobby and not a business.  If you want an IB I would offer $1200.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 6:31am
$500-700 point blank.  to me not worth more than a B.  A good runner B gonna run 750.
Let em sit on it.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 8:22am
Sheet metal looks pretty good including the fenders. Not all IB's had a foot throttle.
I have two IB's. One came with a bad engine. I bought a decent running B, pretty cheap,  that I plan to use the engine in the IB.
I don't know about your area, but IB's are pretty rare around here. Value depends on how bad you want it, but I think $900 is in the ball park.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 8:57am
Better options pop up occasionally. . .just not local (at least none I would mention here ;) ).
Pocahontas, Iowa
I can't make this PA 11/20 ib sale - rough. Looks like it was kept outside for many years.
https://www.auctionzip.com/Full-Image/3598378/fp104.cgi
Edited by KMAG - 15 Nov 2021 at 9:08am
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 12:27pm
From last posted pictures of Auction coming up this Saturday  it's a lot of junk there
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 1:30pm
https://www.auctionzip.com/cgi-bin/photopanel.cgi?listingid=3598378&category=0&zip=&kwd
some of the stuff in the barn looks OK... but your right, all the OUTSIDE stuff looks rode hard and put away wet !
Edited by steve(ill) - 15 Nov 2021 at 1:31pm
JSHIVERS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 5:27pm
It's cool to see this.  I didn't know they made an industrial B model.  I've seen one in
my 15 minutes of collecting.  Thanks for the pics tho.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2021 at 6:03pm
Because its an IB with the rails around it, sheetmetal doesn't look bad, I would say your in the ballpark with your price. I would say $900.-$1200.00.  Yeah, you're going to put a ton of money into it, but like some of the guys mentioned, how bad do you want an IB? The IB I purchased was rough and missing quite a bit of stuff, but I wanted an IB. By the time I was done, I probably threw $2500. at it. But when it was done, I used it quite often pullin' a finish mower to mow the property. Jo Jo loved buzzin' around with it.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 2:24pm
Bottom dollar ib tractors: $500 for two.
These sold in 2020 in Oregon.
ORBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ORBill Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 8:37pm
I watched these 2 on CL for about a month and thought REALLY hard about them. Since I had 13 B's and C's here already I had a feeling that if I came home with 2 more broken down non running tractors it might just end my 48 year marriage no matter how badly I wanted an IB. Sad thing is they were only about 40 minutes from me.
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 8:24am
For some reason that song "I'm gonna miss her" is running through my head!  Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 8:30am
I know Tony Carbaugh bought a couple IB's a while back. Don't know if these two were the same Tractors he purchased... He's retiring at the end of the year, so I'm sure he's going to be "cleaning up". Might be worth a phone call if someone is interested in an IB. Not sure what he's going to have for sale. Give him a call. He advertises on here. Matter of fact, I have to give him a call and see how he and Nonnie are doing. Haven't chatted with him in a while...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 10:21am
Just never understood the get permission from wife thing .
Edited by Fred in Pa - 19 Nov 2021 at 10:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ORBill Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 10:46am
Fred
I only asked permission on the very first one Smile .  The second one was her idea Clap!!!  But being a somewhat rational person with rusty iron disease I thought I had reached my limit when these IB's came up for sale.
Steve
Tony is only about an hour from me so he's my "go to" guy! I've been helping him reduce his inventory by adding it to mine LOL. They are alive and kicking, just suffering from the "aging disease" we all have. As of a month ago he still had both of his IB's, but I might be inclined to take one off his hands. His are not the ones that were on CL, they are in much better shape!
Bill
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 1:02pm
Those  2,  I B`s  are in my  back field  now .  Son  Brian  bought  them ..  I got  to haul  em.      Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2021 at 4:11am
The rusted up IB sold for  $600.
