D-15 and Box Scraper
John-Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Topic: D-15 and Box Scraper
    Posted: 13 Nov 2021 at 9:44pm
I have a 1963 D-15 gas. I am thinking that I need a box scraper and am wondering about the compatibility of a local one here for sale and my tractor. I have a back blade now, but it just doesn't seem to 'cut it'. I have even added an extra 200lbs to it. After a heavy rain, it is still not heavy enough to get below the wash-boarding on our community, 1 mile long dirt road. I think that the shanks on a box blade will be more aggressive to dig down, and because of the box blade design, it may be easier to add additional weight to it if I wanted to. There is one here locally for sale. It is a Land Pride BB1266. It is 66" and weighs 375lbs. It is rated for a tractor 17-30 hp, and in other write-ups about it, talks about it being good for compact tractors. The D-15 is approximately 40hp. Should I look for a heavier box blade which may be more durable for the long run and a more effective grader, or am I just over thinking this and the Land Pride will work good enough? I appreciate any input. Also, if I am missing some trick to make the back blade more effective, I am all ears. Thanks! (Hope this is not too silly of a question for this forum!)
Edited by John-Paul - 13 Nov 2021 at 9:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 9:50pm
375 lbs?? How heavy is your current blade ?? The scarfier shanks would loosen the dirt for sure and then you could blade it. Any box blade I've seen works best with a 2-way cylinder so you can lift the wheels off the ground for more weight. This is a pull-type box blade, Yes ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 6:37am
Pull-type? Yes. I think my current back blade weighs 275 - 300 lbs. The box blade I am (half-way) considering does not have wheels in back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 6:41am
Smaller box blades are generally 3pt implements You most likely want to find a 3pt box blade that is wider than your tires. I'm guessing that you already have a 3pt adapter for your D15, if not the OEM replicas that look like a wishbone are better. than find a set of stay chains than limit the drop of the implement. Sometimes without them you'll end up with more washboarding than you started with.
 When I'm blading with a snap couple blade, I'll reverse the angle every other pass and that helps a lot.  I also have a depth stop on My CA that I use the blade with, That allows the blade to just skim off the high spots. If you can find the depth stop for the rear arms on a D15 grab it.
  A snap coupler blade is built much heavier built than most 3pt ones. You might want to look for a good Snap coupler blade
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 7:52am
Couple of things to consider when a blade won't cut. What condition is your cutting edge? What angle is your blade set at?
If your cutting edge is flat on the bottom, it won't cut very well. It act like a ski, and want to float over the top rather than cut. That can be compensated for if you have the ability to roll the blade forward.
The angle of the blade also determines the amount of cut. The sharper the angle of blade increases the shear factor. If you have it close to straight, it can have a tendency to chatter and increase the washboard. Think of it like a knife. If you just try to push through it takes a lot of effort to cut. If you slice from one side to the other, it cuts much easier. The same applies to a blade. If you have it set straight, it is trying to push the top off the high spot of the ridge. If you have it set at a sharp angle it should slice the top off.
To get rid of washboards, it often works best to cut the material all off, then lay it back down.
I run the grader at work dealing with washboards on our haul road into the D cell. We average 150 garbage trucks in and out, so it gets pounded pretty hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 11:31am
My D-15 does have a 3-point set-up. To tell you the truth, I had not heard of the snap coupler system until now. Thanks for everyone's responses up to now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2021 at 8:28am
Thank you PaulB - I reversed the angle last night when grading and yes, I noticed a difference - it helped cut. I will keep an eye out for the depth stops. Thanks!
Edited by John-Paul - 16 Nov 2021 at 8:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2021 at 8:32am
truckerfarmer - I adjusted the blade to get a better cutting angle, and it looks like that has helped. I will try to sharpen it, also, I guess with a grinder. The blade is bolted on so it is removable / replacable. Anyway, thanks for the tips!
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2021 at 8:44am
DrAllis - Thanks for the help! If and when I get a box blade, the concensus does seem to be to rip it up with a box blade, then to grade smooth with the back blade.  I think I was looking for a one implement/silver bullet  solution. That's ok though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2021 at 8:34pm
You note the D15 as "1963".
Lights on fenders vs. front cowling?
Oval muffler?
FACTORY 3-pt.?
D15II started in 63 but I have seen a couple late D15 Series One's with factory 3-pt. so if you have OEM factory 3-pt. I urge you to check the bolting on the underside of the rear end where the 3-pt. attaches to a plate frame bolted to the under side of the tractor.
Not something you want the bolts working loose on if factory 3-pt. and maintaining a dirt drive will make a 3-pt. blade bounce plenty.
A box blade with removable scarifier teeth (able to un-pin and slide the teeth up after use so you can use the box blade cutting edge) is handy, just keep an eye on the bolting under the tractor as factory 3-pt. on D15SII units is not as robust as the Snap Coupler with SC blade.
I always go with the SC unit although I also have the 3-pt. A-C blades with extensions, when I want to "get rough". SC unit can take far more abuse IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2021 at 5:53pm
I'd go with a wider box, the 15 will pull a 7' box, 5-1/2' barely covers the tire tracks, and won't in a curve.  You say factory 3 point is it the 3 bolts up model, or a wishbone type adapter? Both can be factory...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 10:28am
Sorry for the late reply!
To answer your questions:
Head lights? - they are on the cowling
Oval muffler? - yes
Factory 3-pt? I don't know
I have tried to attach a photo but I can't seem to get it small enough to upload. There is a bit of a wishbone look to the bottom braces / arms, which attach to a plate. I do not see any remnants of a snap couple system, but maybe I am missing something. Yes, I will be sure those bolts are tightened. Actually, they look a little loose right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 11:40am
open your photo on your computer in PAINT and RESIZE to 800 x 600 pixels and SAVE.. Most cameras take 5000 x 3000 size pictures and that is too big for uploading.
Once the photo is the proper size, click on the POST REPLY icon below the last post... Click on the GREEN TREE icon.... then get your photo off your desk top.
Edited by steve(ill) - 24 Nov 2021 at 11:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 2:22pm
Where/ How do the lower 3 point arms attach to the tractor under the transmission ?  The Factory or any aftermarket hitch that uses the snap coupler would be similar to this..
Edited by steve(ill) - 24 Nov 2021 at 2:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 6:20pm
A 3pt Box scraper can easily do all that you are looking for. The scarifier teeth are almost always able to be raised.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 3:51pm
Steve - this is the unit I have, minus that cross stabilizer bar, which is missing. (I will be on the lookout for a replacement.) So I do have the snap coupler? And it sounds like this is a good set-up, correct? Just make sure that all the hardware is tightened up? Thanks for including the diagram!
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 3:52pm
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 5:46pm
If you have that unit, you have a snap-coupler.Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2021 at 8:37am
Good deal. Thank you!
This page was generated in 0.324 seconds.
