6080 injection pump
brouillettefarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brouillettefarms Quote  Post ReplyReply Direct Link To This Post Topic: 6080 injection pump
    Posted: 12 Nov 2021 at 3:28pm
Looking for an injection pump for a 6080 any help would be appreciated.
Thanks,
Ben
812-881-7654
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2021 at 4:18pm
Get one set for a combine !!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 2:26pm
I rebuild pumps here in my shop, and have a core I could rebuild for exchange, or sell outright if absolutely needed. It's almost always less expensive to rebuild your own pump though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brouillettefarms Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 2:43pm
It locked up and broke the input shaft, I've had this before and never had any luck getting them rebuilt, how much for a rebuilt pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 5:54pm
Thats whats supposed to happen - the shaft break as they are way smaller at a certain point  -
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2021 at 8:35pm
If you are braking pump shafts, you need new front plate and dowel pins.             MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 4:23pm
I would rebuild and sell a core outright, or rebuild yours, but with repeated seizures, I am hesitant. If a quality shop has been rebuilding them, then you've got either a mounting/drive issue, or injector issues, as Mack mentioned. I'd want to analyze yours to determine the cause. They rarely "just seize". The above issues, or poor workmanship in repairs can lead to seizures. Those heads are pretty scarce, so I am always hesitant to just hand another pump over. The 6080 pump is the hottest one for the 200 cid, F2/3 combines aren't as strong. The shaft on these doesn't have a small weak area either.
