180 hydraulic main relief valve |
Post Reply ![]() |
ksbowman ![]() Silver Level ![]() Joined: 19 Mar 2013 Location: Paola, Ks Points: 228 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Nov 2021 at 4:37pm |
Checked my Hydraulic pressure today at an auxiliary port and the pressure would go up to 1300 @ 2,000 rpm then drop to 1000. It would repeat this over and over so I assume the valve was popping out at that pressure. Tomorrow I'm going to adjust it as it should read 2,300. Is this much under pressure an indication the pump has worn bad or do the valves go out of adjustment that much thru use?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21907 |
The seals inside the valve fail with age. You'll screw around trying to adjust and probably get nowhere. Then, if you take it apart to reseal it, the adjustment will be too high from messing with it earlier and you could split the pump wide open from too high of pressure setting. Any one I ever resealed, I never once had to change the adjustment....it was pretty much right where it belonged.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8629 |
Yep on splitting pump
rw ![]() Silver Level ![]() Joined: 28 Oct 2009 Location: United States Points: 384 |
yep on splitting the pump also.rw
Rebuilt the main hydraulic valve today and the pressure holds a steady 1400#. May tke it back out and go thru it again. If the pressure doesn't change for the better I'll try readjusting it.
Did you find any blown Orings or back-up rings ???
No back up rings looked bad but the o- rings especially the one on the piston looked tired. I'll disassemble and really look closer at the back up rings. It amazed me how easy it was to get out and take apart on the bench. I had the shop manual out and the total it showed was 4 o- rings including the outers. That was how many I replaced was 4. Was careful to keep everything clean too.
Edited by ksbowman - 08 Nov 2021 at 6:49pm |
Post Reply ![]() |
