WD camshaft grind specs
Jtaylor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Topic: WD camshaft grind specs
    Posted: 05 Nov 2021 at 10:32am
Good morning All,
I am looking for the specs of the 175 camshaft grind to have my local machine shop modify my WD camshaft. Does anyone know the correct specs for this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2021 at 8:32pm
Send it to Berry Cams in Lester Prairie, Minnesota. Make damn sure you tell them you want it reground to an Allis-Chalmers 175 gas farm tractor profile.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 11:34am
had mine ground there,works perfect
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 10:36am
I would like to keep the work local to be honest. I was more looking for lift, duration and correct specs for the locals to grind
