Hydraulic fluid questions???K
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic fluid questions???K
    Posted: 01 Nov 2021 at 12:44pm
I have a 1900 Ford 4x4 tractor. I just drained the hydraulic fluid and cleaned the filter.
It calls for 134 universal tractor fluid. It runs in the transmission and rear differential.
Can I use universal tractor fluid from Tractor supply or such.
New Holland is $75.00 for 5 gallons and TSC has an off brand for $30.00
I need 12 gallons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 1:55pm
The "134" Ford fluid is much like the universal HyTran fluids that are out there. It is the recommended fluid for the SOS transmissions. The "2C53" is a heavier weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 2:07pm
FWIW...I've been using the WallyWorld UTF for years in 3 D-14s....
It's a LOT closer than TSC ( which got bought out by someone....) here in Ontario
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 2:44pm
On the TSC Universal Hydraulic Fluid lists what manufacturers tractors it is compatible with. Most equipment uses the same Hydraulic fluid whether it is IH Hytran,Allis Chalmers 831 or John Deere Hy Guard. Newer equipment uses different fluid and should be checked for compatibility.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 3:10pm
I think New Holland is intent on cleaning out your bank account. Bout did mine for 'can't find anywhere else' parts.
Have a Ford 1320 4x4 all hydro and have run AW32 from Oreally and Napafor 10 years without any issues. Only other fluid is the front diff and engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 4:03pm
I agree with Mark... Check the label on the TSC  bucket for spec... The "very cheap" stuff will have very little specs.... You can get a "good quality" generic in the $30 - 40. range.. It should meet several different specs from JD, Allis, C4, TO2 , Case, etc.... If it meets 20 different specs, its a good quality oil.
Edited by steve(ill) - 01 Nov 2021 at 4:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 4:06pm
I looked up TSC Hyrdaulic oil.. They list a "VP" and this is what is says... i would use it.
  • Suitable for use in older tractors or equipment requiring the following superseded or obsolete fluid requirements: Allison: C-4; Allis Chalmers: C-3; Case: 134, 145, MS 1204, 1205, 1206, 1207, 1209, 1210; Caterpillar: TO-2; Dresser: HMS B806-0001; Ford: ESN-M2C, 134B, 134C, M2C41-B, M2C134-D, M2C48-B, M2C48-C, M2C159-B/C, M2C86-A/B; Hesston-Fiat: AF-87, Multi-F; John Deere: JD 303, JD J14, JDM J20A; International Harvester: B5; Massey Ferguson: CMS M1110, M1129A, M1127A/B; Oliver: Q-1705; Renk Doromat: 873; White Farm: Q-1705, Q-1722, Q-1766, Q-1766B, Q-1802; Sperry-Vickers: I-286-S, M2950-S; Suitable for use in equipment that recommends the following fluid requirements: Kubota: UDT; Denison: HF-0, HF-2
  • Warning: ULTRA J20A Plus Utility Tractor Fluid is primarily designed for use in older equipment manufactured before 1990 or for aging machinery where frequent fluid replacement is required
