HD6 locked in 3rd gear
Joe Goodwill View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Topic: HD6 locked in 3rd gear
    Posted: 29 Oct 2021 at 10:58am
I have our HD6 and blew a shift it is locked in third I believe and shifter is out of place somehow. Can I pop the top off or is this a big project?
Thanks in advance.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2021 at 11:13am
They are pretty simple.  remove the two bolts that the shifter pivots on and pull the shift lever out of the top.  then you can see the shift rails and have a look.  likely you just came out of the gates because its worn.  put in neutral with a bar and check pivots for wear.  you can build up with a welder and/or make new pivot bolts then reinstall
Edited by CAL(KS) - 29 Oct 2021 at 11:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2021 at 8:30pm
common problem on the shift tower being worn
couple things need to be fixed
the bolts into the round tube in yoke wear as does the tube
roll pin through yoke wears and gets sloppy and shift ball at end of yoke slips by shift rails
ball end wears on both flat side and round ball end and slides between shifting rails
All this is easily fixed IF you have access to welder and a lathe
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2021 at 10:23pm
Thanks for the replies! Came apart repositioned the shifter and spent the afternoon clearing trees on fence line. Sweet machine for 60+ years old.
